Question about Sony Handycam CCDTRV118 Camcorder
My zoom is broken
It seems that my zoom is permanently stuck on zoom the switch is completely destroyed so is the little piece of circuit board it lays wondering if there is some manual way to bypass the zoom or to manually work the zoom thanks
    Sergeant:
    Champion:
  • 326 Answers
Hello, there is no way to bypass the zoom or to manually work the zoom. Please contact me at LIVE Expert Assistance. Best regards, Arpi
Posted on Jul 09, 2007
The left mouse key on my Presario CQ60 was a little wiggly for a while but now its completely flat like you cant press down on it and its not stuck cause i can reach under and pull it up but its like the...
The toggle switch is broken, its a small electronic switch that is soldered to the board piece for the mouse pad, only way to fix it is by popping the laptop open, removing the mentioned board piece, and replacing the actual switch with similar model, switch not expensive, but you must have technical skill and tools to handle the repair yourself, otherwise take it to your nearest comp repair shop and be ready to fork out a few bucks...
good luck.
Aug 19, 2011 | Compaq Computers & Internet
My camera Cybershot DSC-W150 has a problem with zoom
Sounds like your lens might be stuck. Do not force it closed or pull it out for that might further damage parts that are an integral part of its sliding mechanism. http://www.teleplancamerarepair.com/Sony_Cyber-Shot_DSC-W150 can repair this for you and they also clean your camera as part of the repair.
if there were any parts you were not able to put together after you opened it , make sure to very carefully put those back to go along with your camera.
Jul 08, 2010 | Sony Cameras
Power will not go on after machine was dropped. Plastic was broken broken on the top of the device near the power connection but the circuit board appears to be undamaged.
The board may appear undamaged, but the instrument's behavior says something is broken. I have no idea what kind of musical instrument this is, but circuit boards are all the same.
Especially on boards with narrow circuit traces and surface mount parts, damage can be very hard to see. A trace might have a hairline break which would be impossible to see without bright light, strong magnification, and some idea where to look.
It's also possible that the board is fine, but some part has been damaged. The lead from some part may have broken away from the circuit trace, for example. Or a small surface-mounted component may have popped off completely or had a lead broken off.
Unfortunately, this kind of trouble is very hard to fix without detailed product information (circuit diagrams and board layout). Unless the manufacturer makes a service manual available to the general public, this means sending the unit back to them or an authorized service center for repair.
Feb 03, 2010 | Zoom Music
My zoom 505 2 distortion pedal for my guitar will not function with batteries and the ac adapter slot is loose in the back, please help
I have had this same problem with mine, since the adapter jack is loose it's probably broken loose from the circuit board inside. I had to carefully dis-assemble and re-solder the adapter jack back to the circuit board. This is un-fortunately a weak point on some of Zoom's pedals, when you or if you get someone who is good at soldering to do it for you ask them to beef the solder joints up a little to help keep it from coming loose again. I re-did mine and I've never had another problem with it.
Mar 09, 2009 | Zoom Music
Won't zoom out
This seems to be a common issue.
Mine was stuck at what seemed like max optical zoom.
When i would look in the lens I could not see the zoom lens. If you can not see your zoom lens and the optical zoom seems stuck I bet your camera has the same STUPID issue that mine has.
It was out of warranty and I figured I had nothing to loose so I took it apart to see if I could fix it, turns out I was able to fix it just by taking it apart and putting it back together!
Taking it apart is simple enough for the average handy man, if you do not have confidence that you can take it apart then do not attempt this repair.
Take off the bottom cover.
Take off the Hard drive cover
Now remove the three screws under the hard drive that hold the drive's plastic housing in.
Remove the screw that is right under the record button, now the drive house should be loose.
Disconnect drive cable from board and remove drive and housing.
Take off the plastic piece that has the zoom button, be sure to gently disconnect the wire.
Remove rear piece.
That screw marked with an arrow on the bottom, do not remove it!
Now remove the thin metal piece to expose the flat cable.
disconnect flat cable from board
gently flex it out of the way so you can disconnect the cable behind it.
Once you have both disconnected remove the circuit board.
unplug the flat cable on the back side.
Now remove the front piece.
At this point you are nearly there!
Now remove the metal housing that holds the lens assembly.
Once removed remove the lens assembly by removing the three screws.
If you thought that was bad, this next part will scare you.
Make sure you are in a very clean room with no fans blowing.
Remove the CCD from the rear of the lens assembly by removing the two screws on the back that hold it in place.
Remove the foam and square lens piece that were behind the CCD.
On the side of the assembly is a screw that holds the top cover in, remove it and gently pry off the top cover.
looking inside you will find the following:
on the CCD side is the focus lens.
in the middle is the shutter
On the side farthest from the CCD is a zoom lens.
On mine the zoom lens was not close to the shutter
If your zoom lens is not close to the shutter then you likely have the same problem as I had and you can fix yours!
If not, you likely have some other issue :-(
To fix mine I turned it over and I loosened the screws that held the motor and shaft for the zoom lens.
Then I slid the zoom lens as far back as it would go towards the shutter.
Then tightened the zoom lens motor and shaft mount.
Put it all back together, installed battery and bingo it's working again!
Why did this fix the problem?
Well there is a little sensor that tells the camera that the zoom lens is near the shutter.
Each time you turn off the camera it always puts the lens in that "home" position.
If the camera is turned on when the zoom lens is not in this "home" position then the camera seems to assume the zoom is broken and you end up with the infamous JVC stuck zoom issue.
My guess is this problem is caused by any of the following:
1. Removing the battery while the camera is turned on
2. Dropping the camera while it is on or off
3. Battery going dead while camera is in use
Final thoughts before you get started:
1. If you are not good at working with tiny parts or electronics, I wish you luck because you will need it. Might be better off printing these instructions and taking them with you to a repair facility and paying someone more familiar with this sort of work to fix it for you.
2. The ribbon cables are removed easily. Each one has a clamp that rotates to release the ribbon. Some rotate towards the ribbon to release, others work the opposite. It is quite obvious looking at them which ones go what way.
--e100
Sep 03, 2008 | JVC Everio GZ-MG21 Camcorder
Broken lock switch zune Pink
My zune lock switch completely broke off in the locked position. I used a paper clip to remove the small plastic tray under where the switch use to be. It came off pretty easily. Then I could see a small black toggle switch can I was able to flick it in the unlock position.
Jun 17, 2008 | Microsoft Zune JS8-00001 Digital Media...
TV in permanent zoom
The left and right arrows on the RCA remote control are the picture format buttons.....
Apr 12, 2008 | RCA P61939 61" Rear Projection Television
Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Oct 19, 2007 | Canon PowerShot A95 Digital Camera
Panasonic DMC-TZ1
I just had this problem, too. I basically disassembled the camera by removing the back cover, front cover, and top assembly. The top assembly includes a plastic part between a circuit board and the top external metal piece that houses the button on the top of the camera. On the circuit board there is a switch for the zoom that looks like a pinball flipper. You have to make sure that it's working properly and you may have to remove the metal dust cap and remove any sand if it's lodged in the mechanism. It's pretty tough if you're not good with your hands because it's extremely small. I did this and the zoom began working like normal again, but then I got the message that the camera needs to be turned on and off every time I turn on the camera...
Sep 26, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Olympus D-595 Zoom
I don't know anything about this camera. However on most modern cameras, the Shutter Button is usually just part of a switch. Nearly always there is a rubber Diaphragm below the button, which has an electrically conducting lower surface. When the Button is pressed that surface touches a small printed circuit board, or part of a circuit board, and a number of circuits are closed. It could be that the lower surface has become stuck to the Circuit board, or the rubber diaphragm has moved and is jammed down. It might be possible for you to open the case, and get to this switch. Any other switches or buttons near by, will also become loose, so remember which goes back where. If you don't want to take any chances I would advice you to find a local repairer, who should be able to fix this fault very quickly and fairly cheaply. Good luck
Jun 09, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Sony Handycam CCDTRV118 Camcorder Logo
217 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
