Question about Samsung ML2955DW - ML-2955DW Wireless Mono Laser Printer
ML2955DW paper keeps jamming inside the printer
My printer suddenly keeps jamming the paper. It rolled the paper 1/2 way then jam. I pulled out the paper, reprinted and it jammed again. No matter how I feed in/out the paper, it just jammed inside the printer
SOURCE: paper jam
Open the front cover and look at the white roller. Is there anything jamming that? Like, say, a broken clip that's meant to hold the front cover in place as I just found happened to our fax machine.
Posted on Apr 27, 2007
  • 16 Answers
SOURCE: jammed paper message
I get a Jammed paper message on the read out, I have cleaned out all the paper and pressed stop/cancel button but it still keeps saying that there is a paper jammed in it.
Posted on May 09, 2008
  • 4 Answers
SOURCE: remove jammed paper
I had the same problem.
I found that the gears driving the printhead cleaning mechanism was jammed.
To solve this, I removed the top cover (6 screws and a clip centre bottom, back).
Please take care when working on the Fax machine as there are high voltages present.
It is best to always remove the power sorce when working on electronic equipment.
I removed the cleaning mechanism (2 screws)(you have to remove the circuit board next to it to get to the one screw). I did not disconnect the ribbon cable from the circuit board, only the two smaller cables.
Once removed, I gently tried to rotate the cleaning mechanism by turning the plastic gears. It should rotate freely by 360 degrees. If it sticks at all, there is most probably some dirt stuck to one of the gears. Using a magnifying glass, carefully inspect the gears for dirt and gently remove the dirt with something thin and pointy like a bag needle. Be sure to check that the gears are still adequately covered in grease afterwards.
Reassemble and test before fitting the top cover.
I do not know why they set the fax up to give a paper jam when this item jams but this was the problem on my fax.
Good luck and I hope this solves your problem.
Regards,
Gary
Posted on Feb 28, 2009
  • 3 Answers
SOURCE: CONTINUING PAPER JAM
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Posted on Apr 17, 2009
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
Had paper jam which have cleared. Getting support code 6001 saying turn off and restart which we have done but still keeps coming up with same error
The 6001 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
Aug 24, 2016 | Office Equipment & Supplies
A piece of paper jammed up. I took the paper out but the alarm keeps on saying "Carriage jammed"
Hi there !
Check again your printer and maybe there is still paper jammed inside. Turn off your printer. Open the door cartridge and remove the cartridge. Check for paper jammed. After that return the cartridge and turn on your printer. Sometimes there is paper jammed inside that printer. Just press the power off and turn it on to roll over any paper jammed inside. Turning off on your printer also make your computer refresh the memory of your printer paper jammed.
To make hard reset of your printer. Turn off your printer and remove the power cable to your printer, leave it for five minutes and connect the plug and turn it on again. That will refresh the memory of your printer.
I hope it helps you.
Jan 25, 2011 | HP Officejet 7310 All-In-One Printer
Our printer is not picking up the paper from the tray and is saying it is jammed. There is not jam.
Hi there !
Is your printer had jammed before and it stop printing in the middle of printing? For some reasons, paper can jammed due to printing interruptions, printer turn off, improper loading or feeding of paper, roller feeder had problem and others.
If jams before and paper have let inside the printer, please do the following first:
1. Check th paper tray, see inside if the paper is jammed inside that compartment. If there is paper jammed, remove, turn off your printer and turn on. This will solve your problem.
2. If not, open the printer cartridge door, remove the toner cartridge and look for paper jammed inside. If these is paper inside, remove it, turn off the printer and turn it on.
3. If you cannot see the paper jammed inside, the paper maybe inside the heating area. To remove paper, just turn off your printer and turn it on to roll over the paper jammed inside of it.
4. If the printer is blinking and saying there is paper jammed. You have to check the cartridge toner by opening the cartridge door, remove the cartridge and return it back but be sure it is well firmly fitted.
If following the 4 diagnostic procedure and you cannot locate the jammed paper, the problem lies on the toner cartridge itself. When toner cartridge is not rolling over, it will stop feeding the paper and it will cause printer to jammed.
To diagnose the problem, put old printer cartridge and if no toner power, just shake it well and I am sure there is still small amount of powder inside it and if it prints, the toner cartridge you purchase is defective. Reason, factory defect or improper refilling and part is not working well.
I hope it is helpful and thank you for using FixYa !
Jan 06, 2011 | HP LaserJet P3005n Printer
Can't get it to work after a paper jam.
Inorder to remove the paper jam inside, you need to remove the toner cartridge first and then you can pull out the paper jammmed. If there is still paper jammed inside. Open the printer power to roll over and paper comes out. If still paper still there, You can open the back side of the printer to remove some paper jammed.
Nov 13, 2010 | Dell 1320c Laser Printer
Paper is jamming during printing process. Gets half way round and jams. please suggest solutions
There are rollers that the paper has to go between to be pulled forwards. When the rollers get dirty with paper dust, paper starts jamming. So you need to clean the rollers with a moist (not wet) soft cloth, Keep rolling the rollers manually and keep cleaning them. Then allow a few minutes to dry them up. And no jam after that.
Dec 10, 2009 | Dell 1100 Laser Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Samsung ML2955DW - ML-2955DW Wireless Mono Laser Printer Logo
532 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
