Question about LG WM2487H Front Load Washer
Error message E1 - LG WM2487H Front Load Washer
  • LG Master
  • 17,129 Answers
It means there is water leakage in hose connections or there is damage to the hose that results in water spilling or leaking.
Your observation to the washer's inside is needed to confirm the leak and solve.
check this link Leaking machine
Posted on Jan 15, 2013
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Grohe Blue - Error E1
    You have to disconnect the power supply for more than 30 sec
    Nov 03, 2015 | Grohe 31251 Blue Chilled & Sparkling Dual...
    Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
    Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
    True Treadmill Errors and Service Messages
    • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
    • The error messages that may be displayed by the built-in diagnostics are as follows:
      • E1:INCLINE
        • This means that the incline is moving when it has not been commanded to.
      • E1:MINIMUM
        • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
      • E1:RANGE
        • This means the difference between the treadmills zero position and maximum incline is not sufficient.
      • E1:STALL
        • This means that the incline is not moving when it has been commanded to.
      • E2:OVERSPEED
        • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
      • E2:CAL
        • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
      • E3:EEPROM
        • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
      • E5:SENSOR
        • This error occurs when there is no speed or RPM feedback detected from speed sensor.
    • The service messages that may be displayed by the built-in maintenance reminders are as follows:
      • S1:LUBE
        • This service message displays when it is time for inspection of the deck lubrication system.
      • S2:CLEAN
        • This service message displays every 500 miles and is your prompt to clean the treadmill.
      • S3:MOTOR
        • This service message displays every 2500 hours and is your prompt to check the motor brushes.
    • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
    Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
    Oct 12, 2015 | Exercise & Fitness
    Get error message "E1"
    Hi nickweekes36,
    Please check my following tip for the full solution to your problem.
    Click here -> L.G E1 Error / Whistling Sound
    Kind Regards :-)
    * If you found this solution helpful, please rate it.
    Jun 27, 2011 | LG Dishwashers
    Call for Service error message E1-12
    hi E1-12 for image processing unit ,
    thanks
    May 14, 2010 | Sharp AR-235 Copier
    E1-Error message is apparently the fuse were is
    The E1 error message. This is due to the fuse having to be switched from the 2.5 amp to a 3.5 amp. they did not recall the machine because of the low cost $2.99.
    The Fuse is Located on the Board itself.
    I guess the Part Number for your model is 000182177.
    You could Purchase that from :-
    http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=000182177&productGroupId=0020&supplierId=385&pathTaken=&filterPart=&pop=flush
    Let me know, if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Apr 23, 2010 | Kenmore 19233 Computerized Sewing Machine
    19606 E1 MESSAGE HELP
    E1 error message is a blown fuse problem.
    Check out this site it shows you how to fix it http://www.sewingmachineryrepair.com/forums/index.php?topic=79.0
    Feb 27, 2010 | Kenmore 19233 Computerized Sewing Machine
    Treadmill cuts out after 10 seconds and gives an E1 message.
    Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
    Good luck.
    Jan 23, 2010 | Horizon Exercise & Fitness
    Error E1 mean?
    An E1 error message usually indicates that the thermistor (see the following link) is defective and needs to be replaced.
    http://www.appliance411.com/data.php?rc=548392
    pls rate my suggestion...
    Jun 26, 2009 | Whirlpool Washing Machines
    Kenmore Elite quiet pak 9 dryer
    Error message E1 indicates the temperature thermistor has failed.
    Jun 22, 2008 | Kenmore Elite HE4 Electric Dryer
    LG WM2487H Front Load Washer Logo
    22 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
