Question about Bose Lifestyle SA-2 2-Channel Amplifier
How do i connect an aux signal to a bose sa-2
3 Suggested Answers
  • 263 Answers
SOURCE: bose terminal block connector
http://www.4electronicwarehouse.com/products/bose/ta2-adapter.html
Posted on Aug 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: how can I conrol the volume of bose sa 3 amp from the aux input ?
That would depend on the preamp. Name it. A true preamp outputs a variable signal.
It's not clear from the manual what the state of the volume output is without the VCA. Most amps default to full ON and the preamp attentuates the signal with a volume control. Try it with a signal that fades in slowly so you can intervene if it gets too loud. If it's full ON a preamp will control its volume.
Posted on May 29, 2010
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
Can I connect my Bose wave music system to my LG LED TV LB55, lb56,lb62
Of course.
At the rear of your TV, find the Red and White RCA sockets, which are the Audio OUT.
At the rear of your Bose, find the Red and White RCA sockets, which are the AUX IN.
Using an RCA audio cable, connect those 2 pairs of RCA sockets.
Then, on your Bose, select AUX as the source, and if you've done EVERYTHING correctly, your Bose will now be the speaker system for your TV.
Feb 22, 2015 | Bose & Wave& Music System
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
How can I conrol the volume of bose sa 3 amp from the aux input ?
May 28, 2010 | Bose Lifestyle SA-3 2-Channel Amplifier
Can i hook my BOSE SA1 Stereo Amplifier to my computer?
If it has a tape/aux imput/output yes!
All you need is to connect suitable cables between them.
If your computer has jack sockets and the amp RCA type, use the type shown below:
Apr 20, 2010 | Bose Lifestyle SA-1 Amplifier
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Bose terminal block connector
Aug 02, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
SA-2 and SA-3 doesnt work together
its alwaays better just to call bose their great when it comes to this
May 20, 2009 | Bose Lifestyle 18 System
Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Mar 25, 2009 | Bose 3 2 1 GSX System
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Bose Lifestyle SA-2 2-Channel Amplifier Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
