Bush TV Stuck In Standby Mode?
So I got this Bush TV a while back and I noticed something about it fairly early in the fact that it would stop working for approximately 12 hours if I unplugged it from the wall? it didn't bother me too much though because I'd just leave it plugged in at all times, now it did this every time I unplugged it until about a month ago, my brother came around and accidentally unplugged it from the wall and ever since it has never turned on again? It just stays in standby mode and will not turn on no matter what I do, I've tried every button on the TV & every button on the remote but neither does anything, could it have anything to do with the TV fuse? this is really beginning to bug me now because its not under warranty anymore and I can't really afford to buy a new TV just yet so I'd love if someone has solution! This is what it says on the back of the TV by the way! BTVD91216B Bush 19" HD Ready Digital LCD TV with built-in DVD Player AC 230v - 50Hz Power Consumption : 45W
    Top Expert:
  • Televison & ... Master
  • 40,473 Answers
Could be an open internal fuse or power supply failure
Posted on Mar 06, 2017
  • 6993 Answers
SOURCE: My TV stopped working two days ago. The red
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like ""(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Posted on Jun 17, 2011
SOURCE: tv stuck in standby
I believe these Sony TV's have a built in obsolesence and Sony does not care about fixing them. I don't think a 7-year old TV is an "old model". Who can afford to by an expensive TV every 7 years. Shame on Sony.
Posted on May 01, 2007
  • 56 Answers
SOURCE: DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
Posted on Jan 22, 2008
  • 213 Answers
SOURCE: My Samsung LCD LA32R7 won't
you have a bad power supply.
Posted on Jun 11, 2008
  • 744 Answers
SOURCE: Dmtech TV is stuck in stanby mode
thank u rate me!!
Posted on Feb 12, 2009
The power for my bush tv model number led26982hdt
My bush television wont turn on from standby? - Ask Me Fast > Consumer Electronics > PlayStation > Wont
Hi my bush tele wont turn on it just keeps flashing at me standby light i ve changed the fuse .... Bush 22 inch tv dvd combi keeps restarting remote doesnt work.
22" bush tv wont turn on - The Student Room > ... > Sound and vision
The Student Room
Mar 12, 2012 - 12 posts - ‎7 authors
i got a new tv in january from argos and not had a problem with it until now. The problem is that it just stays on standby and wont turn on. the ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
Apr 27, 2014 - Uploaded by Keith Fox
Hello my bush 22 inch tv is messed up Say if i go on it one day it..... it wont turn on from the power botton on the back not from the control ...
Jan 10, 2016 | Bush Televison & Video
Bush a642f tv stuck in standby mode suspect power supply capacitors but all seem ok
Press and hold the menu button on the t.v (not on the remote) for about a min, this should reset the processor to unlock it.
Aug 17, 2015 | Bush Televison & Video
Grundig lcd tv standby stuck
Inverters use square wave voltage, which tends to stifle digital circuits. Leaving something stuck, or not working. Sure, the inverter will work for awhile, but then the rigid square wave eventually causes problems.
Feb 02, 2014 | Polaroid Televison & Video
TV stuck in standby
have you looked at power supply as you might have to change the caps on the power supply
Jan 25, 2014 | Bush Industries IDLCD26TV16HD LCD TV
Problem with a bush BTV185DVD
The screen off light is stuck on on my Bush TV/Video/DVD combi BTV185DVD. I have tried to turn it to standby but then it just goes back to "Screen off" and nothing happens to the screen. Please help.
Feb 24, 2010 | Televison & Video
TV switching to standby
Hi.i had exactly the same problem with my bush 37 inch lcd tv and i took it to a friend of mine who is a t.v electrician he said it was a component in the back of the tv which he replaced and its now working fine.
Jul 05, 2009 | Televison & Video
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Stuck in Standby
change the horizontal output transistor .its busted.
Aug 14, 2008 | Bush 5693D 24" TV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
