Question about Kitchen Ranges
Owners manual for a 3448xtw magic chef range/oven
The top burner for the top of the stove where is the ignitor located
Demy
  • 20 Answers
SOURCE: Magic Chef Gas Range
Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
Posted on Aug 01, 2007
fridgetech
  • 473 Answers
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
  • 1314 Answers
SOURCE: Magic chef oven
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
Posted on Jan 21, 2008
battlesmith
  • 382 Answers
SOURCE: lighting pilot light on magic chef gas range
Hello Jim,
Try to replace the ignitor if it is more than 3 or 4 yrs. old..If it not that old then Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When you release the knob, the flame should stay oN. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on!!!..Thank you...
Hope this helps you!!...
Regards!!!....
Posted on Jul 24, 2008
SOURCE: Magic Chef oven won't light
Replaced the ignitor.
Posted on Oct 09, 2009
Why won't my oven ignite? The stove top burners work fine, but I can't seem to get the oven to work. It get's warm, but I can't see that the gas is working.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 15, 2011 | Magic Chef CGR1110 Gas Kitchen Range
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
Magic chef self ignitor top,, how do u get the oven to work.. is it self ignite too. i turn on oven ger a glow in the oven,, dont know the model ,,older stove. good shape. bought house with gas stove...
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Tom
Aug 10, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef gas stove... oven does not work... It uses the ceramic unit to ignite which glows but gas does not come... Both the broiler and top burners work
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 05, 2010 | Kitchen Ranges
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Pilot lights
you need to plug the oven in; pull it out and you should locate the pwr cord or you may already have it plugged in and have a breaker turned off or a gfi tripped
Jun 19, 2008 | Magic Chef Kitchen Ranges
Jul 29, 2007 | Magic Chef CGR1110 Gas Kitchen Range
Oven will not light. Ignition element will not even turn on
I have a magic chef gas range and the top of the stove burners work , the broiler works but not the oven..I think it is the glo bar. How the heck do I change this? It is a magic chef proven cooking performance from model # 8114p627-60 from about 1999
Jul 15, 2007 | GE EGR3000 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
