Question about Advansys ABP 3922 (500003-00-10) SCSI Controller
I need windows 7 driver for Advansys pci abp-3922 scsi
Do windows 7 drivers exist for Tekram DC390F?
The information that I can find indicates that Tekram stopped making drivers for this card with windows 2000. It is likely, that it was natively supported in vista with generic drivers. Due to the age of this card, it is unlikely that you will find drivers that will work reliably in windows 7.
Jul 15, 2014 | Tekram Computers & Internet
Getting Acer ScanPrimo ST 1220ST to work with Windows 7 and a PCI host adapter with an LSI20329IE Ultra 320 using a VHDCI 68 PIN TO CENTRONICS 50 PIN (CN50) CABLE
Acer ScanPrimo ST 1220ST to work with Windows 7 and a PCI host adapter works just fine I use it every day. The key is to use a third party scanner software called Vue Scan 9.0.57 and using the following start-up procedure so Windows 7 can find the scanner on the SCSI controller. First open windows device manager, then turn on scanner, immediately right mouse click in device manager and select scan for new devices. Windows 7 will immediately find the scanner. It seems that windows will only see the scanner through the SCSI interface during the scanners startup sequence. It has been a while but I believe this works with Mira Scan V4.03 as well.
Sep 22, 2011 | Acer ScanPremio 1220ST Flatbed Scanner
I have transfered a LSI20160 SCSI card to my new 64-bit Windows 7 PC, but I cannot find a proper driver for the card.
I'm assuming its a driver issue.
The installation cannot proceed. Can the Vista Driver be used? Or do I need a Windows 7 specific SCSI driver?
If the Vista SCSI driver can be used how does one use the Vista driver with a "Clean" install?
Aug 06, 2011 | LSI Logic (LSI20160LP)
How do i use an epson filmscan 200 with a laptop running windows 7
were you using it under windows xp? if you have 32 bit windows 7 I would try those same drivers. Unfortunately the filmscan 200 came out under windows 95/98 and so Epson never released XP drivers and some people were able to make it work.
I would consider connecting it to an older computer running windows 98 and then transfer the files as you scan them (this would definitely be the least painful)
If you have 64 bit windows 7 I would not even waste the effort, 32 bit is a long shot maybe.
Do you have scsi drivers on the the windows 7? because the filmscan 200 is a scsi 2 device
Good luck
Nov 24, 2010 | Epson FilmScan 200 Film Scanner
SCSI to USB conversion for Film Scanner
SCSI to USB converters are available, but I doubt they will be of much help for you, you'd still need a special driver for your scanner.
Windows 7 Professional, Enterprise, and Ultimate support "XP Mode", essentially a Windows XP environment running in a virtual machine. I'd try to get the SCSI interface card and scanner to run inside the VM as a workaround.
Feb 07, 2010 | Acer ScanWit 2720S Film Scanner
Epson Perfection 1200 Scanner Driver Needed for Windows 7
I posted this for another user but i'll post it here too,
I remember looking for hours for a driver for my Epson 1200 scanner back when I upgraded by dad to Vista 64 Bit, eventually I found one. Just today I upgraded him to Windows 7 64 bit and remembered I couldn't get it to work, luckily I was able to dig up the driver I used for Vista 64. Worked great in Windows 7.
I can't remember where I found it so I can't credit the person who made the driver unfortunately, however i've uploaded it to Rapidshare for you to download. Here is the link:
http://rapidshare.com/files/324940248/epsonScan_1.0_Per1200Win64eu.zip.html
Just open up the zip file and run the setup. :)
Hope this helps, Merry Christmas!
Dec 16, 2009 | Epson Perfection 1200 Photo Flatbed...
How do install drivers for a pci-sc200 scsi card ?
Good Day Sir, Try the link below it will help you setting up pci-sc200 scsi.
users manual
Nov 01, 2009 | ASUS PCI-SC200 32BIT PCI SCSI CONTROLLER...
Adaptec AHA-2940 UW PCI SCSI CONTROLLER
If you are using Windows XP, the drivers are embedded. It will automatically recognize the SCSI card. For other OS try http://www.adaptec.com/en-US/support/scsi/2940/AHA-2940UW/ S. Mohan.
Jun 09, 2009 | Canon Office Equipment & Supplies
Advansys ABP 3922 (500003-00-10) SCSI Controller Logo
189 people viewed this question
Top Advansys Computers & Internet Experts
David Payne
David Payne
Are you an Advansys Computer and Internet Expert? Answer questions, earn points and help others
