Question about Advent by Audiovox ADV10PS2 Overhead Flip Down 10.2 inch LCD Monitor with Sony Playstation2 DVD Game Console, PS2 Games, Headphones and Controllers
In my new (used) car I have this ADV10PS2. The parental control is set for the DVD (and maybe playstation) and won't allow some movies. I have no idea what the code is nor how to get it so that
When I put in SHARK TALES the parental controls block it from playing. A screen comes up asking if I want to override for this movie. If I say yes, it asks for code. If I say no it tells me to eject the movie.
When I put a dvd in the sony playstion 2 slim it says (This movie will not play due to the parental setting of the player) how do I remove parental restrictions for dvd's & cd's Thanks
In settings there is the parental lock code. If Bought Brand new, then the defaut password is usually 1234, so give that a try. After which you can set it to the most allowing setting, which i believe is 8 and then any movie shoud play. However if you have set a password then you either need to reset it with a PS2 format disc.
Please Rate
Sep 05, 2011 | Sony PlayStation 2 Slimline Console
There was a parental lock code on our ps2 when we got it, is there a override code I can use to unlock it? I bought it at a yard sale last summer and they never mentioned that they put a lock on the DVD......
Try these directions, they *should* work.
1. Insert a DVD Movie into the PlayStation®2.
2. You should receive a message informing you that the Parental Level has been set, and asking if you?"d like to allow the disc to play. Highlight "Yes" and then press the X button.
3. A new window will appear asking you to temporarily change the Parental Control to a different level. Again, highlight "Yes", and then press the X button.
4. Another window will appear asking you to enter your Password. Above that window are numbers (0-9).
5. Do not enter your password, but instead, press the select button on your Controller. This will change the text in the window from "Enter Password" to "Delete Password".
6. Using the numbers above the window, input 7444. If successful, you will receive a message stating "Deletion Complete".
7. Press Select. You will now be asked to register a new password. Please select a four-digit code of your choosing.
8. You will be asked to confirm your password selection by inputting the same code once again. If successful, you will receive a message stating "Registration Confirmed".
9. Now you need to turn off the password altogether. The movie should of started playing by now. Press select and chose Setup. Go to the parental control "tab" and set the level to "off".
10. Now you should be able to watch any movie
Apr 05, 2011 | Sony PlayStation 2 (PS2) Console
I have followed all directions to turn off parental controls on my ps2 but it will not let me. what should i do?
Follow these steps:
  1. Turn on the PlayStation 2 and remove any disk that may already be in the device. Then insert a DVD, preferably one that will prompt you for the parental control code. Insert the code and allow the DVD to begin playing.
  2. Press the "Select" button once the movie has started. This will bring up a menu. Find the "Settings" icon, and press "X" to enter the "Settings Menu." Scroll down and select the "Parental Controls Menu" and press "X."
  3. Reset the "DVD Parental Control Level" to "Off," which will allow any DVD to play without prompting the user for the passcode. You may also choose to set it to level 8, which is the least stringent level.
  4. Do not exit the menu after inputting the new settings. Instead, eject the DVD and remove it. This should cause the PlayStation to reset with the new settings enabled. If it does not automatically reset, then manually reset it by either flipping the switch in the back, or by holding the reset button in the front down. Leave the device off for a few seconds.
  5. Turn the PlayStation back on and input a DVD that previously required the passcode. The PlayStation should now play the DVD without prompting you for the passcode. If it does, then you're finished. If it still prompts you for the passcode, then start again at step one and try it again.
Feb 27, 2011 | Sony PlayStation 2 (PS2) Console
I can do all directions to get rid of parental controls, but when i go to turn the controls off, it will not let me. what do i do? do i need to send it back to get a new one cuz this is very...
You should be able to turn it off using these steps:
Lost password cant watch movies on playstation 2
2. You should receive a message informing you that the Parental Level has been set, and asking if youý"d like to allow the disc to play. Highlight "Yes" and then press the X button.
All credit for this write up goes to the member POST (revised by UnhappyKlown3). hope this helps please remember to vote
Nov 29, 2010 | Sony PlayStation 2 (PS2) Console
Need to reset code
Found this on another site, from personal experience but its very well written so here you go.
The Playstation 2 is not only a video game system, but also a DVD player as well. In many families, the Playstation 2 serves as the "kids" DVD player, which means that many parents choose to take advantage of the parental lock feature to limit what kinds of movies the Playstation 2 will play back.
There could be instances where you entered in a parental code months ago, and now can't remember it. Or, you may have purchased a used Playstation 2, and you never knew the code to begin with. If you or the prior owner set a parental lock code, the Playstation 2 won't play back many movies without entering the code first. You could try to hunt down the original owners, or start inputting every code possible starting with 0000, but it's easier to reset the password and disable parental lock using a secret code.
Here is the procedure to reset the parental lock code:
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
Please rate accordingly
Justin
Jul 28, 2010 | Sony PlayStation 2 (PS2) Console
Need to know how to turn off parental controls
Apr 24, 2010 | Sony PlayStation 2 (PS2) Console
Parent advisory code, can't play kids movies
Jan 07, 2010 | Video Game Consoles & Games
Changing parental control
Start the PS2 up and load the DVD. When it shows the Parental screen select YES. When the Password box pops up. Press the Select button on the controller. Type in 7444. Then your password is reset. It will ask you to enter another password. Do that twice. Allow the movie to start. When it gets going pause the movie, Press the Select button on your controller again. The DVD menu pops up. highlight SETUP. When that setup screen appears go to the 3rd icon from the left. Press X. Then highlight Parental Code. Set the parental lockout level to OFF.
Nov 20, 2007 | Sony PlayStation 2 (PS2) Console
Advent by Audiovox ADV10PS2 Overhead Flip Down 10.2 inch LCD Monitor with Sony Playstation2 DVD Game Console, PS2 Games, Headphones and Controllers Logo
44 people viewed this question
Top Advent Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Advent Audio Player and Recorder Expert? Answer questions, earn points and help others
