Question about Maytag Performa PAV2200
Vibrating with or without clothes as if out of balance
I have checked the springs, the belt, the moter, the pulley all seem fine. Tried leveling the feet. It has been working fine for years. Only moved it to put in laminate flooring.
  • 1 more comment
  • cmjjd Jan 27, 2009
    Wow,, same problem. We moved ours onto a hardwood floor. It's now vibrating out of control...have to brace myself against it to use it. Had it looked at by a repairman...replaced the snubber and still the same prob. It is level but still walks and vibrates way too much. Help!
  • Anonymous Jan 29, 2009
    We have tried leveling several times, running only smaller loads (which defeats the purpose of the large tub), had it checked and was told it is fine and working as it should. It is so loud, we can hear it on the next floor!
  • kimeley Feb 05, 2009
    We had the same problem. We had an extended warranty on our unit and have had the repair guys out three times. Each time, the person was insistant that the problem was fixed. As soon as you put more than 5 towels in the washer, the machine would vibrate so loud it would walk across the floor. Finally, after at least 10 phone calls to Lowes and the extended warranty people, Lowes is sending us a new machine. I appreciate the Service Manager at Lowes, I did not appreciate the customer service we received through A&E service at all.
  • 95 Answers
Vibrating or rocking? try pushing the drum around manually in the washer front back right left.re check level.
Posted on Jan 23, 2009
What's broken to make washing machine drum unlevel
If this is a front loader washer then the springs holding the drum in place (inside the washer) are weak and off balance or the bearings are damaged.
Need some detailed mechanical check. See this post on this topic.
Front loader washing machine shaking vibrations Laundry Room Forum...
Aug 07, 2014 | KitchenAid Washing Machines
Frigidaire fws747rfs1
The washer tub bearing may be defective, but that is the only thing that I can think of. Are you noticing this on all loads or just heavy items like bath towels and jeans? Are you redistributing the clothes before the final spin, try that. Also do not overload the washer, wash to medium loads instead of one full to the top load. Wastes water but saves on repairs.
Apr 12, 2017 | Washing Machines
Platter vibrates; doesn't rotate smoothly
Do one thing Remove the palter and put one drop of lubricating oil in the center shaft. Also put one drop in the motor shaft. Be carefull do not drope the oil in motor pulley. If so clean the pulley with a cloth. Because it will cause slipping the belton the pulley.Then put the plater back. Rotate the plater with arms for some time. Then check.
Ajin
May 07, 2012 | Numark ttUSB Turntable
Maytag washer model PAV2300AWW does not spin the clothes adequately and vibrates Is it the belt or Snubber?
Might just be a belt which is real easy to replace, no tools needed:
Take that belt off there and check the stiffness of the pump.
These will lock up or get stiff without even leaking.
If that pump seems fine check to see if the main drive pulley is properly releasing the tub in the direction of spin. Their are 2 marks on the pulley, the drum should release in between the two points. if not then the thrust bearing kit needs to be replaced.
I have a pictorial of that and a service manual HERE
Jan 30, 2011 | Maytag Washing Machines
My LG DLE2516W dryer has a bad vibration to it. Do you know what might be causing it? And how do you take it apart to try to find the problem?
try looking at the spring and belt on the motor inside the dryer.some times you can spray wd40 on the pulley the belt is on going to the motor.make sure the levels on the bottom dryer are spun out to the right adjustment.should make sure washing machine spins most of water out of cloths.
Aug 07, 2009 | LG DLG5988 Gas Dryer
Need to balance washing machine drum
The drum should not need balancing, but the washer should be level in all directions. If the washer is level, but vibrates excessively during spin cycle, you may need to replace the springs. There is a set of suspension springs which act as shock absorbers. When these wear out the washer will bounce across the floor unless the clothes are 100% balanced in the washer.
Jul 29, 2009 | GE Washing Machines
Ford 302 in E-150 is turning all drive belts into dental floss
Here are a few choices. If equipped with A/C the air could ice up the compressor and stop the a/c clutch, shredding a belt. Width of belt pulley, if narrow pulley has fat belts and fat pulley has narrow belts, then possible to shred. Has anyone cranked down the damper on the crankshaft? If the bolt comes loose or the woodruff key is worn you could get a wobble from the crank.
Apr 22, 2009 | Ford E-150 Cars & Trucks
Washer vibrates and seems to be off balance
hey i have the same problem and have been looking for help we bought ours last night and have tried several times to wash clothes. We're level front to back and diagonally. The bolts on the feet are screwed tight to the appliance and still in slow spin mode it sounds like it is off balance and it vibrates and shakes and is kinda scary if you ask me.
terri
Mar 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
123 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
