Question about Maytag Washing Machines
I have a maytag washer part number mvwc300vwo the motor just hums but wont spin
landsend
  • 1066 Answers
SOURCE: maytag atlatis mav8551aww washer runs fine til spin mode then
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: My maytag washer model PAV3300AWW will not spin
Check the belt at the bottom of the machine. You can also remove the back panel. Either the belt has become stretched or broken and needs to be replaced
Posted on May 22, 2009
  • 64 Answers
SOURCE: maytag washer will not spin. motor overheats and drum won't turn
If it has a belt try loosening the belt and see if the transmission and pump will turn and are not stuck.
If they are they will have to be replaced. Try the motor and see if it turns freely with the belt loose or off. If they all turn freely check motor.
Posted on Jun 10, 2009
  • 82 Answers
SOURCE: washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Posted on Jul 29, 2009
  • 464 Answers
SOURCE: seized tub - Maytag pavt244aww washer
you may have a seized up pulley on your pump. this will burn the belt. also check the pulley on the end of the motor.
Posted on Oct 27, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
My maytag washer model #mvwc300vwo made a loud noise. Shut it off & tub moves around now. Help
Belynda, possible tension/balance spring has broke or detached, also could be a problem with the transmission drive, in any case a technician will have to diagnose and repair.
Apr 12, 2016 | Maytag Washing Machines
Thunping or banging noise during wash cycle may tag MVWC300VWo quiet during spin
You will need to pull the basket and check the drive block.
Here is a video to show you how to get to the drive block.
Dec 03, 2012 | Maytag Washing Machines
Washer wont agitate or spin motor hums i canturn
Jul 29, 2009 | Washing Machines
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer will not spin. motor overheats and drum won't turn
Jun 09, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Nov 29, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washer fills up, motor hums, but no spin.
sounds like the drive belt is broken these models have pump belt and a drive belt
Oct 16, 2008 | Maytag LAT2300 Top Load Washer
Washer wont run but is trying to
Sounds like the motor or capacitor (next to the motor), the capacitor helps the motor to start, once running a switch inside the motor disconnects the capacitor from circuit.
Mar 18, 2008 | Maytag PAV2300 Top Load Washer
Won't Run
The humming usually means the motor is trying to start but can't either because of weak windings or not enough electrical power. Need to check the motor control.
Mar 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
