Question about Eemax Water Heaters
I have Eemax EX65, The light and click doesn't start.
The red strip button doesn't move down and is hard to the touch. No burn smell. This is the second time, because 1 month ago, show the same and i disconnect for 1 week and works properly again, bout now, never start again. Thanks for all.
4 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Eemax SP3512 not works intermintently, more off than on.
you have a clogged filter turn off the water on the unit on both sides, right below the unit there are 2 caps one on each side take the cap off there is a filter in side, clean it and reistall it that should take care of the problem, you might want to flush out the system while your doing this also
Posted on May 29, 2009
  • 48 Answers
SOURCE: My water heater cuts of after 30 seconds and shows C2, 11 code
sounds like your gas lines are too small or not enough pressure... or you may have to clean the rods
Posted on Jan 16, 2010
heatman101
  • 43501 Answers
SOURCE: I bought a 30gal Reliance
Hi Bill,
Your problem now is that the thermocouple is getting weak. I assume that you have checked and cleaned the burner again with no improvement in the function of the burner.....
You may be getting some moisture in the gas which can cause the flame to go yellow, but will notmake it go out...
If everything else is okay, then I would be changing that thermocouple before doing anything else... they are inexpesive and easy to change.
heatman101
Posted on Apr 19, 2011
No water coming out from outlet.
What product? eemax sp2412/
http://www.homedepot.com/catalog/pdfimages/e2/e289142e-792b-48ed-9b6a-bae87550a046.pdf
Is this new installation or older installtion that worked before?
Have you cleaned the inlet water filter?
Hs unit exposed to hard water?
Has unit been delimed before?
Have you disconnected supply line under sink to see if problem is faucet?
Gene
h
Aug 31, 2013 | Eemax SP2412 2.4kW 120V
Hot water not coming out
Tank-type Electric water heater?
Press reset button.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add comment and describe water heater, and more detail about problem
Mar 30, 2013 | Eemax "Flow Controlled" Electric Tankless...
Pilot light will not light
If your pilot on your gas water heater will not stay lit you need to take one step at a time.
Let's look at how you tried top light it. Turn the gas valve to the off position and then move it to the pilot position. If you can see inside under the heater and there is no glass view window you need to take a lighter or a match on an extended stick so the flame can sit right under the pilot tube. Push down on the red button and then the gas should light on the pilot burner. Hold the button down for a FULL 60 seconds.
Then slowly release the red button the main burner should then come on. Now if the pilot flame goes out right away as you're releasing the red button you have one or two more things you need to look at.
1st would be to replace the thermo coupling. You have to remove the whole burner tray to do that. If that does not work then the gas valve is bad and you need to replace it also. Make sure that when you buy a new gas valve you match up the gas type Natural gas to L P gas. They must match with the gas feeding your house or it will never work,
Thanks and best of luck
R J
Sep 08, 2011 | Rheem Water Heaters
My gas water heater pilot light will not stay lit
Hi Mike,
1stly you have to understand what the pilot light does!
Yes, it lights the flame, but it protects you from gassing yourself!
that is thye main job!
hava a look inside!
In front of the pilot flame, (it might have a double flame... (one flame on the bottom & another on top.) is a curved piece of metal plate. The flame is supposed to heat that plate untill it it very hot! Thenm the plate bends down as it is a bimetyaalivc strip!
This opens the bsaety valve & you can let go.
The flame will noe stay on. If a gush of wind blows the flame out, the strip will cool & the safety valve close, preventing a dead family in the morning.
There is a newer system as well.
Right in front of the flame, is a pointed sensor with it's tip in the flame. . It has a electric cable running to a safety valve. This sensor have to heat up as well. It is a heat battery that activates the valve. See that it did not move!
If it heats up, & the valve does not keep the pilot flame going after a few seconds, the unit has to be replaced!
Safety first!
Andy
Sep 04, 2011 | Water Heaters
Have Model EX380T2T2 Serial # 777604. Have purchased two EX630 heating elements and installed them. Water got hot for about a week. One more old heating element burned out. Fixed it by reattaching to...
A lot of problems can contribute to this problem.
As you know, tankless cannot be exposed to water with more than 11 grains of hardness.
Tankless require softener and filter system which can affect line pressure and flow, which will adversely affect tankless unit.
The problem could be clogged sensor, bad board, but still that doesn't explain burned out elements unless the elements were coated with sediment.
Sediment build up will kill a tankless within 2 years and render it useless and unfixable.
Yearly deliming will not restore functionality.
If pressure is a contributing factor, you can add a pressure tank that will even out the pressure.
All in all it looks like the pressure sensors and other sensors are crashing.
Call service technician, and glean from that person the tips and tricks.
Read the manual for advisories and required yearly maintenance.
You can fix this tankless problem yourself, same day, by installing $207 tank-type electric water heater from box store. Offer 10% less and also buy flexible connectors to connect to existing water lines. The cost of running and maintaining electric tank-type is cheaper long term. All costs are energy.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
May 01, 2011 | Eemax EX380T2T2 Series 4 Whole House...
My house has 200 AMP Service, will this work ok with the EEMAX EX380T2T2? It requires 4 40AMP Breakers.
your water heater will take a 160 amps of you service. I would not install one if it was me. The total demand in the dead of winter with furnace, water heater and lights on will cause you to brown out.
Oct 05, 2010 | Eemax EX380T2T2 Series 4 Whole House...
Where is the reset button on Eemax t120
hi its the red button in the control pannel but make sure the power to the heater is turned of please rate this answer
Nov 19, 2009 | Water Heaters
I have a Sime Super 90 Combi Boiler. How do I start the pilot light? Thanks
does it have a little red button on the right hand side of the gas valve? if so you must put the gas valve button in the pilot positon and push it down and hold it, then click the red button {push it down} it will click and look at it keep clicking while holding down the button on the gas valve eventually when the gas gets thru it will light could take several clicks of the ignitor
May 18, 2009 | Water Heaters
We are currently updating or eemax heaters with the newer control
have you tried eemax.com go to customer service lititure request... they also have a tech support number... if you need more help feel free to contact us as sales@heaterup.com
Apr 11, 2009 | Eemax SP4277 Single Point Electric...
My eemax ex120tc 11.5kw 240v the water does not get hot enough.
you can check elements with a meter to see if they are any good. how old is heater?
Feb 04, 2009 | Eemax EX120TC 11.5kW 240V
Water Heaters Logo
24 people viewed this question
Top Eemax Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you an Eemax Water Heater Expert? Answer questions, earn points and help others
