Question about IBM Office Equipment & Supplies
IBM Selectric shift key stuck - IBM Office Equipment & Supplies
Coldcut
  • 1554 Answers
SOURCE: Selectric III Key Stuck
remove the cover , latch on bottom each side of unit.
turn it on is the belt running or jumped off.
if it is running then the clutch is jammed.
Posted on Jan 25, 2008
JayBlair
  • 328 Answers
SOURCE: return key is stuck
Need more info. Many different possibilities.
Posted on Aug 12, 2008
  • 3594 Answers
SOURCE: Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
DickyO
Posted on Apr 07, 2009
  • 4 Answers
SOURCE: Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
Posted on Apr 19, 2009
  • 3594 Answers
SOURCE: how to remove the cover from an IBM selectric.
First remove the platen. There is a lever at each end of the platen push them down and remove the platen.
Then inside the case on both sides are levers, pull them towards you and remove the case. The levers are inside the case right against it.
DickyO
Posted on May 19, 2009
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
IBM Selectric Model 71 keys are locked up and won't depress.
First thing try every key one may be partually tripped. Try the shift key that may be out of adj. Most anything eles you will need a tech.
DickyO
Dec 23, 2009 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
On the IBM selectric 2 - the keys are locked up -
Try the shift key, then try pressing each key on the key board one may be partially tripped.
DickyO
May 07, 2009 | IBM Wheelwriter 30 Typewriter
IBM SELECTRIC III, won't print
try turning the metal shaft that the carrier is on. turn it towards the back of the machine.
Apr 10, 2009 | IBM Wheelwriter 30 Typewriter
IBM CORRECTING SELECTRIC II TYPEWRITER
Is the key stuck in the down position? If you pull the key off you should see a spring underneath. Maybe out of position or damaged.
Aug 10, 2008 | IBM 3500 Typewriter
Jan 25, 2008 | Office Equipment & Supplies
78 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
