Adora door locked
Replaced gasket, turned on and door locked.
  • Washing Mach... Master
  • 17,129 Answers
Click on Door lock
Posted on Jan 15, 2013
I have a GE Adora M# DSF25KGTABG. Set temps on the freezer door to 0 and 37. runs great for a few days then drops down to -9. I have replaced all thermistors and the mother board. What would be the next...
I have the GE Adora DSS25KSTB ss and the temps will not hold to cool temp.
We set it at 0-25 and the refg to 35 and sometimes it will cool to that temp and then sometimes it is a lot warmer.
Dec 29, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
GE (Side x DSide) Adora: closing fridge door causes the freezer door to open
That will happen if you close the door too quickly or make sure the freezer door gasket is sealing properly.
Nov 20, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Machine flashes F then dl. What can we do?
There's a fault detected with the door lock and switch assembly. The door lock is not working or the door lock switch is not activated. This indicates that the door lock and switch assembly is malfunctioning and needs to be replaced to address the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Using needle nose pliers, start where the spring and wire are connected and pull the wire out of the groove of the door gasket.
Remove the three screws securing the door lock and switch assembly to the front panel.
Gently peel the part of the door gasket near the door lock and switch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock and switch assembly behind the front panel.
Slightly lift the door lock and switch assembly then pull it back off the front panel and out of the cabinet.
Transfer the wiring harnesses to the new door lock and switch assembly one at a time then install it in place behind the front panel. Secure the
door lock and switch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Install the retaining hoop with the spring positioned at the bottom of the door gasket.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My door lock has locked with the door open , how do i get it to unlock ?
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the toe panel to the cabinet then pull the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall for an easy access of the screws.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side.
Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GE Adora door locked after power surge and can't get it to unlock and come on
You probably need to replace the door lock mechanism. Try unplugging it and then plug it back in. If that doesn't work, you probably need a repairman, or someone with more electronic feature knowledge.
Dec 24, 2009 | GE WSXH208A Front Load Washer
GE Adora front load wont lock the door or start at all. GE service is not existant.
the door switch has broken and needs replaced can be got online,adrian;;;;
Nov 11, 2009 | GE WSXH208A Front Load Washer
Door seal ripped , model is GE Adora GHDVH670HWW. I need a part number for this seal, cant find anything anywere
This is the model that was made by GE to be sold exclusively though Home Depot stores. The cross over model is the GE WCVH6600H0BB
The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since the GE Adora line might be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
I'd suggest you call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you order any repair parts, so you can be certain they'll work for your washer.
It's a relatively easy repair, all you need to do is remove the nuts and washer at the top and bottom of the cabinet all around the opening (once you've opened the door) to get the counter balances off, so you can access the gasket and remove it and replace it with the new one.
Here's a line drawing that shows the exploded view of the tub section, with the gasket (item #306). Just take your time in removing and reinstalling the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fGR708157-00004.png
Hope you find this Very Helpful and best regards!
Aug 25, 2009 | GE Washing Machines
Lights blink and it kind of chugs. wont start
If the door isn't fully closed it won't automatically lock. Our's was improperly installed so it really had to be closed hard to get it to lock. To re-set it can take up to 90 second's,the door has to remain locked during this time.Unplugging the unit may re-set it. the door Hopefully this will help out.
Aug 22, 2009 | General Electric Adora GHDA670N Built-in...
Door panel doesnt work
Check circuit fuse,electrical connections,check your door circuit & buttons.
Feb 21, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
