Question about Sony BDPS480 Bluray 3D Player
Netflix resent sony bdps480
I have already "reset all settings" in the setup menu, but when I go to netflix it still automatically pulls up my mom's account. I'm trying to put my account on it in its place. To make things more complicated, I don't have the original remote because this was a display model and I'm using a replacement universal remote. Please let me know if there's something I can do.
bluegreenash
  • 661 Answers
SOURCE: Sony DVP-FX810
You need to use a One4All Universal remote for regions 1 & 3
1. Switch on the player
2. Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
"One4All" is the model of remote
Posted on Apr 18, 2008
  • 3 Answers
SOURCE: DVP-S560D will not play some dvds, C:13:00 flashes at bottom of screen
Try using a Laser Lens Cleaner disc - get the "wet" type that uses fluid. Target stores carry an inexpensive one.
Posted on Jun 01, 2008
SOURCE: Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Posted on Apr 03, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony RDR-VX450 DVD/Video. I cany use the remote as
All you need to change remote control mode to DVD 2 so unit can receive DVD 2 remote signals.
Press and hold Enter and numeric 2 buttons on remote control for 3-4 seconds, this will change remote mode to DVD 2 in remote control, now dvd recorder will get DVD 2 signals and can be operated normally. No need to go back to DVD 3 mode.
Hope these info will help you.
Thanks.
Posted on Jan 19, 2011
  • 152 Answers
SOURCE: Halo, i lost my original remote and bought ''Sony
Order a replacment of the origional online. eBay would probably have it. http://www.sony.newremotecontrol.com/catalog_item.php?catnum=147854511
Just found it after a short google search.
Steven Cumming
stevencumming@hotmail.com
Please leave positive feedback :-)
Posted on Jun 05, 2011
How can I delete the privacy policy on my Sony Bravia smart tv so I can watch Netflix?..?
see links
SONY EU ' Support - How can I enable or disable the Automatic ...
sony-eur-eu-en-web--eur.custhelp.com/.../how-can-i-enable-or-disable-the-automatic-...Assuming you agreed to the Sony privacy policy during the initial setup of the TV, the Automatic software download setting from your TV is turned ON by default.
privacy policy on my Sony Bravia smart tv Google Search
Nov 19, 2017 | Sony Televison & Video
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
My Sony Blu Ray was working fine. I bought a used blu Ray it skipped and froze(the BD player was completely unresponsive) I had to unplug it to power it off for awhile. Then I tried watching Netflix and It...
There should be an option in your setup menu to perform a reset. Reset all settings to factory defaults and try it then. This will sometime sfix this problem. If not, then you are looking at a really expensive replacement main board that will cost you more than the unit is worth
Mar 25, 2015 | Sony Televison & Video
How do I set up netflix via wii?
I asume you setup your WiFi connection, so next you have to:
1)Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii.
2)Select "Free 0 Wii Points.
3)Select either the "Wii System Memory" or an "SD Card" as the download location( In case you have a SD card plugged in).
4)Select "OK," then "Yes" to download the channel.
5)Once Netflix Instant Streaming for Wii has finished downloading, it will appear on the Wii menu.
6)Once installed select Netflix from the Wii men?.
7)When asked if you are already a Netflix member, select "Yes" to reach the Member Sign In screen. If you are not already a member, select "No" and fill out the required fields on the screen to begin a free one month trial.
On the Member Sign In screen, click "E-mail."
8)Using the onscreen keyboard, enter the e-mail address that you have associated to your Netflix account, then click "Enter." (This is the same e-mail address you would use to sign into Netflix.com.)
9)Select the "Password" area, and use the Wii Remote to enter your Netflix account password. Select "Enter" when finished.
10)When your e-mail and password have been entered, select the "Continue" button.
11)Once you have successfully signed in, the Wii will automatically display your Instant Queue.
Nov 01, 2014 | Nintendo Wii Console
How can you reset a Sony DBD-S3200 to go through the setup process again?
According to the manual, locate the Reset menu in the menu tree. You should have the option to set it to Factory Settings
Here is a link to the manual
https://docs.sony.com/release/bdps1200_bx120_s3200_bx320_s5200_bx520.pdf
Dec 28, 2017 | Televison & Video
The movies want play
  1. Test your Internet Connection
    1. From the PS3 main menu, navigate to Settings.
      • If you're not already at the main menu, hold the PS3 button in the middle of the controller, select Quit, then select Yesto return to the home screen.
    2. Select Network Settings.
    3. Select Internet Connection, and verify it is set to Enabled. If it's Disabled, make sure to select Enable.
    4. Select Internet Connection Test.
      • If you are able to connect to the Internet, check your date and time settings.
      • If you are unable to connect to the Internet, you may be having network connection issues.
  2. Refresh your Netflix Iogin information
    1. Begin from the PS3 Home Screen.
      • If you're not already at the home screen, hold the PS3 button in the middle of the controller, select Quit, then select Yesto return to the home screen.
    2. Navigate to the TV/Video Services section and highlight Netflix.
    3. Press X.
    4. Immediately after pressing X, press and hold both Start and Select and continue to hold them down until a message appears asking Do you want to reset your Netflix settings and re-register?
    5. Select Yes.
    6. Enter your Netflix email address and password.
  3. Reinstall the Netflix application
    1. From the PS3 Home Screen, navigate to the TV/Video Services section and highlight Netflix.
    2. Press the Triangle button on the Playstation controller.
    3. Select Delete.
    4. Select Yes.
    5. Download the Netflix application to your PS3.
    6. From the PS3 home screen, navigate to the TV/Video Services section and select the Netflix icon.
    7. Select Yes on the Are you a member of Netflix? screen.
      • You may be prompted to sign in to your PlayStation Network (PSN) account first.
    8. Enter your Netflix email address and password.
  4. Troubleshoot your Internet Connection
Oct 22, 2013 | Netflix
How do you set up netflix on your Panasoni TH-42PZ85U?
Hello
Currently, all three video game consoles on the market are compatible with Netflix "Watch Instantly:" Sony Playstation 3, Microsoft Xbox 360 and Nintendo Wii. All you will have to do is download a free application for your console. Playstation 3 users can find this application on the Playstation Network and Wii However, Xbox 360 users will have to pay a yearly Xbox Live subscription to access Netflix's video stream.
Many new models of high-definition Blu-Ray disc players already have Netflix applications. Several different manufacturers include this application, from high-end brands like Philips and Panasonic to generic brands like Vizio and Insignia. These players often include other popular internet applications, such as Facebook and Pandora Internet Radio. Also, new TiVo digital video recorder models have a built-in Netflix application.
Select HDTV models already have a Netflix "Watch Instantly" player as a pre-installed application. All you will have to do is run the Netflix application from the TV menu screen and you will be able to watch streaming Netflix movies and TV. Brands that have been including Netflix on their HDTVs as of 2011 include Sony, Sanyo, Panasonic, Vizio and many others.
Several of the same companies that manufacture Netflix ready Blu-Ray players also have full surround sound home theater sets with the same features. Though Netflix Watch Instantly does not currently support surround sound audio, this feature will be implemented in the future. Brands that have been supporting Netflix in their home theater packages include Panasonic, LG, Samsung, Insignia, and Sony.
May 05, 2011 | Televison & Video
How can i delete a netflix account from my panasonic viera tv without accessing the netflix account?
Disregard the other solutions. Open your Netflix App and do the following:
Hit the arrow keys on your remote.
Up, up, down, down, left, right, left, right, up, up, up, up.
Jan 11, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Sony BDPS480 Bluray 3D Player Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
