Question about Toshiba TLP-LF6 Projector Lamp for 670UF, 671UF, 68
Resetting the lamp counter on Toshiba tlp 670
Please help with resetting lamp. bulb has been replaced and after about 4 minutes it turns off. Need to know how to reset the hours back to zero.
How to reset Toshiba Projector Lamp MODEL TLP261
Posted on Jul 18, 2009
AFTER REPLACEMENT OF TOSHIBA PROJECTOR TLP791 LAMP IS NOT WORKING . PLEASE SUGGEST THE LAP TIMER RESET METHOD. R K MISHRA SATNA MP INDIA
To reset the lamp hour of Toshiba TLP791, do the following.
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
The lamp reset procedure is over.
ok
Jul 16, 2011 | Toshiba TLP 791 Multimedia Projector
Reset lamp timer
If you go into the info menu you should see lamp hour meter, should be option there to reset it.
only do so if you have put in a new bulb as bulbs can explode if they go over the hour usage time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Toshiba TLP S30 Multimedia Projector
How to reset the lamp counter for Toshiba ELP-X3000 model after repalcing the lamp
Hi
Go into the menu.
GOto status in there you should find the lamp timer reset.
Many thanks
Feb 15, 2011 | Toshiba TLP-X3000 LCD Projector
I have the model TLP WX 2200 and doesn't turn on and after a few minutes, the ON led is green, is blindnig and a bip is heard. After a while, the two of three leds ( on and lamp ) are getting red. What...
It seems lamp is dead/ broken in projector, please check lamp and replace it to fix the problem.
There is lamp cover at bottom side of projector, remove lamp cover to take out lamp.
Detailed procedure of lamp replacement is written in user manual page-45
Click Toshiba Support link to download user manual free copy, if required.
Thanks.
Nov 10, 2010 | Toshiba TLP-WX100U LCD MOBILE PROJ WXGA...
How do i reset lamp hours for a toshiba TLP-T721
I have not actually tried this but on a different post, here's the wild solution:
Reset the lamp counter hours of operation for the projector TOSHIBA TLP-T720
Sep 02, 2010 | Toshiba TLP T721 Multimedia Projector
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Jan 08, 2009 | Toshiba Replacement Projector Bulb...
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Toshiba tlp670u
This is due to filter problem you can clean the filter other and put it back this one reason.
Another one it might me problem with cooling fans any one of the fan speed will slow or failed. Please check the same and replace.
Regards,
prakasam
Mar 05, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Toshiba TLP-LF6 Projector Lamp for 670UF, 671UF, 68 Logo
1,278 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
