Question about Maytag Washing Machines
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
Maytag 4000 series front loading washer 18 months old with brand new inner and outer drum and bearings.
  • Maytag Master
  • 17,130 Answers
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Posted on Jan 15, 2013
KOakaKO
  • 135 Answers
SOURCE: Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
Posted on Aug 04, 2007
Krazytech
  • 725 Answers
SOURCE: WAsh machine drum bearing removal
check out the tommy tool on youtube .it will show you how to do it even if you don't buy the tool...
http://www.youtube.com/watch?v=F3Wrq6Yxra8
let me know krazytech
Posted on Aug 13, 2008
  • 5 Answers
SOURCE: Water Leak from the Front Door of our Maytag Epic MFW9700S
The water leaking is most likely the gasket. It may have a little rip or something making it not seal. Im not sure about Maytag but on our GE we had to slide the the top back to remove some screws then (I believe to was for the control panel) Then we removed screws for the door and the front of the washer. When that was done you have to remove a round clamp that holds the gasket on. Then replace the gasket.
My suggestion is to have a appliance repair come and do it. Its a pain to do, at least it was for me.
Posted on Jan 28, 2009
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Posted on May 25, 2009
  • 14 Answers
SOURCE: Duet GHW9150P inner SS drum is actually loose but
go buy new washer the drum bearings have gone and it really is not worth repairing . it can be repaired but always found that it never lasts long once done.
Posted on Jul 07, 2009
Why does the washer door drip water onto the floor when opened?
Check the gasket on the body of the washer entrance. Pull open the crease and check the drainage holes for lint, etc.
Oct 18, 2014 | Maytag Washing Machines
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2013 | Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    What is the best way to clean the mold off the door gasket
    I use to have the exact same washer. When Maytag was Maytag before the merger with Whirlpool they suggested using a mixture of bleach and Sunlight power dishwasher detergent. You can also usually find a washing maching cleaner like Tide washer cleaner or Washer Magic. Run it on the longest and hottest wash cycle. Stop the maching during the wash portion and wipe the door seal down well with a rag and ware gloves. Also make sure that the little drain hole in the center of the bottom of the door boot (gasket) is not not blocked up with lint or anything. If your mold problem is really bad you might have to call a repair man out to replace the gasket and clean inbetween your inner and outter tubs.
    Feb 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
    Black stains on door
    If it is inside, it is probably mold growing. Front loaders are much more susceptible to mold growth as they seal up tighter, and we all tend to keep the door closed when it is not in use.
    Clean the inner door and bellows surfaces with a 50/50 bleach/water solution, applying liberally, and dump the rest into the tub of the washer. Add 1 more cup of bleach to the tub. Fill all of the dispenser cups with bleach. Run the hottest , longest cycle available with the hottest rinse cycle available. For us, it is the "sanitary" cycle. Run a normal cycle immediately thereafter to flush out residual bleach, and leave the door open. The cleaning along with the air drying will keep the mold from growing, and reduce the odors that these machines are famous for. Leave the door open between loads.
    Best regards, --W/D--
    Jan 23, 2011 | Zanussi FJS1225W Front Load Washer
    Nd code in display .... not spinning
    reviewing similar complaints from other posts ,, removed pump assembly, removed the three screws holding pump to housing assembly,cleanad and reassembled (found build up of lint and soap/softner residue) this repaired the pump , but unfornatley the rear bearing is noisey , and is not a reccomended repair too costly .. many thanks
    Dec 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Epic Z Washer has object between drum and tub.
    did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
    Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
    Power window problem. engauges then disenguages
    Section 01-11: Glass, Frames and Mechanisms 1997 Windstar Workshop Manual REMOVAL AND INSTALLATION Door Glass and Regulator, Power Windows Removal
    svw~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
    1. Remove front door trim panel (23942) and front door inside panel sound insulator (20394). Refer to Section 01-05 .
    1. Remove inside door belt weatherstrip.
    1. Remove front door window glass (21410) as described in this section.
    1. Remove two nut and washer assemblies attaching the window regulator equalizer arm bracket (23230).
    1. Remove four rivets retaining the front door window regulator base plate to door inner panel.
    1. Remove front door window regulator (23200) and front door window channel bracket (23288) from vehicle.
    1. Working on a bench, carefully bend tab flat to remove front door window regulator arm slides from front door window channel bracket.
    1. NOTE: Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket. Make sure rubber bumper is installed properly on new front door window channel bracket, if replacement is made.
      Install new front door window regulator arm plastic guides into front door window channel bracket and bend tab back to 90 degrees.
    Installation
    NOTE: The front door window channel bracket and window regulator electric drive (23394) are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Door Glass and Regulator, Power Windows .
    1. Install window regulator electric drive with preassembled front door window channel bracket into vehicle. Set the regulator base plate to door inner panel using base plate locator tab as a guide.
    1. NOTE: Two 1/4-20 x 1 inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (35-44 lb-in). Equivalent metric retainers may be used.
      Install four rivets to retain front door window regulator to door inner panel.
    1. Install window regulator equalizer arm bracket.
    1. Lower front door window regulator arms to access holes in door inner panel. Install front door window glass as outlined.
    1. Install inside door belt weatherstrip.
    1. Adjust front door window glass to make sure it is properly aligned with glass run. Check window for smooth operation.
    1. Install front door trim panel and front door inside panel sound insulator. Refer to Section 01-05 .
    Item Part Number Description 1 21410 Front Door Window Glass 2 23288 Front Door Window Channel Bracket 3 23394 Window Regulator Electric Drive 4 23230 Window Regulator Equalizer Arm Bracket 5 222A00 Front Door Glass Run Latch Side Retainer 6 N621906-S36 Nut and Washer 7 N800510-S36 Screw 8 23200 Front Door Window Regulator 9 W525172-S Rivet 10 W525175-S Rivet 11 — Wire Connector (Part of 14630 Wire Assembly) A — Tighten to 7-10 Nm (62-89 Lb-In)
    Apr 13, 2009 | 1997 Ford Windstar
    Washer stops
    Initially, pls open the lower access panel (bottom of your washer) by removing the 3 torx screws. There would be a sheet that lists the error codes. The panel pulls forward and down, inside mounted on the right side taped to that inner panel would be the above described sheet. Additionally, to my knowledge, this indicates a door latch fault, the machine cannot activate the lock or senses that the door is not closed or the door is not locked.
    In some instances, the error code F/DL could be triggered be a loose component. This could be that the plastic fitting on the door is loose and therefore will not latch on the locking assembly or the locking assembly itself is loose. You could then try opening and closing the door a couple of times.
    Should this be not corrective, then the logic controller board may require close checking.
    Good luck and Thank you for using FixYa. Happy Holidays.
    Dec 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Clothes come out oily after wash
    Hello
    Welcome to fixya.
    I'm Huuum and happy to assist you,
    You said,you have a Eurotech front loader. Lately you have observed that your cotton materials come out with oily spots after wash. What can one use to address this problem.
    In most front loaders when this happens it is usually either of two things.
    1.Front loaders must have HE detergent for their use and if you do not use HE detergent you must cut your detergent and bleach in half.
    Because to much detergent destroys your seal and eventually your bearings! And any other rubber seals like the rubber door seal in the front opening.
    These degrade and get into the wash and depending on the color of the rubber (Black or gray) are found to stain your clothing or leave a residue in those colors.!
    Those washers with Grey rubber like Maytag's have gray stains and or residues!
    I have people asking me about this problem every day!
    Call the manufacturer and ask if they have any cleaner that you can run once with out clothes to put an end to this!
    And then use HE detergent and or half the dose of bleach form now on!
    I hope this brings some lihgt to your problem. Please let me know what the Eurotech proplr tell you to use to clean it out of your washer!
    Please remember to leave a rating before you go!
    Thank you
    Sep 29, 2008 | EuroTech EWC177 Front Load Washer / Dryer
    Washing Machines Logo
    404 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
