Question about Jensen VM9411 Car Video Player
Tv has sound but no picture
I have the jensen vm9411 everythinng works the only problem i have the tv function has sound but no picture i used the bypass code for the dvd and never hooked up the parking brake wire so that i can drive and watch a movie i need help to fix so i can get a picture from the tv
thanks in advance
    Scholar:
  • 116 Answers
Should be the same bypass. Do you get any message when you put it on a TV station? Guess what, after Feb 17th, it won'y matter anyway unless you're going to get a digital converter for it!
Try grounding the pink brake wire and see if that does anything. As far as I remember, that bypass is for ALL video on the screen. Let me know.
Peace,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
I have a jensen vm9411 i was wanting to know if i have to have the brain for it to work at all
Once installed the device is expected to least malfunction unless any damages were experienced. Refer to the user guide to ascertain the features that are enabled to achieve full satisfaction as new owner. Most recent devices are wireless remote controlled to allow for owners operation convenience. Use the remote control to explore through the several unique functions to attain user satisfaction. Also recognize the capacity to perform with menu function keys or buttons that controls the entire settings of the device.
Feb 02, 2011 | Jensen VM9411 Car Video Player
How to bypass the parking brake switch for an 06 jensen VM9411
Here is the solution
1/ insert the dvd movie
2/After the disc loads and plays you will seea blue screen telling you "it is unlawful to drive with a movie bla bla bla"
3/Activate the brake sequence and disable the blue screen using the hand brake,the switch method or anything else to give the unit its 3 pulses to disable that freakin blue scrreen.
4/Next,on the main remote press stop twice,then 1,2,6,4.
5/You will now see a hidden menu that says.
Region Code
Brake Override(I know you are droling by now)
Macrovision(Watch all the burned and pirates you want if this option is off)
Loader Version
Model Version
6/Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle
on ,off or witch region code you want.
7/This is what you want.
Region code 1
Brake override ON
Macrovision OFF
When your done,click SYS SETUP on the remote TWICE to save the settings and vingo.
Mar 09, 2009 | Jensen VM9510 Car DVD Player
Is a media link box and media module the same for jensen vm9311ts
they are not the same. the media link will work for that model.
Jan 17, 2009 | Jensen's VM9312 Car DVD Player
Bypass code
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 15, 2008 | Jensen VM9411 Car Video Player
Jensen Model Vm9411
take it to a repair shop to clean the lazer probably is dirty.
Jul 03, 2008 | Jensen VM9411 Car Video Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
How do you install the dvd portion so i can view movies
I have Jensen VM9411 I put code 1264 and disable my remote control now is not working and my screen is not working
Aug 22, 2007 | Jensen VM9411 Car Video Player
Car Audio & Video Logo
193 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
