Question about Frigidaire GLTF2940ES Front Load Washer
I can't get the LOC error code off my fridgedaire frontload washer, the magnet is in place, the door shuts fine, I don't know what the problem is?
  • johnd1025 Jan 25, 2009
    I have the same problem ,started this morning, "lock code" door shuts fine, but once I push the start button I get the Lock code and the green light will not light next to the lock sign? Washer will not start! Help!
  • bellagirl26 Jan 26, 2009
    johnd1025 - thanks for the answer, the manual says the same thing, for some reason it would not work for me. I did however get it to turn off, I unscrewed the two screws in holding the lock in place and then it fell in the door and I was able to put it back into place and re-screw it in. Now the error light is off. However, having replaced the "coin catcher", check all the hoses for clogs etc., I still can't get my washer to wash. It was just starting to add the water and then six seconds into it, it would stop and do nothing. Now it just clicks and hums and nothing happens. I think I'm beyond something I can fix myself. However, if the repair who is coming on Tuesday comes and has a simple fix I have overlooked, I'm going to go crazy, it will cost me $200 to have him come out, always does:(
    Thanks again.~Bella
Push options and select button at the same time to unlock
Posted on Jan 25, 2009
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
Frigiaire frontloader washer will not operator error code " LOC "
To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Nov 15, 2011 | Washing Machines
This washer has an error code of DDO, Dispenser door open, would you think a sensor issue or something more?
The meaning for ddo error means"Dispenser Drawer Open" .To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
My GLTF2940ES0 WON'T START it's cycle. An error code "ddo" displays
The meaning for ddo error means "Dispenser Drawer Open"
Thank you !!
Jun 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2009 | Kenmore Elite 45986 Front Load Washer
Error code LOC
Jun 27, 2009 | Kenmore 44932 Front Load Washer
Te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Jan 10, 2008 | LG WM-2277HW Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
233 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
