Question about Gateway CUSTOM E-SERIES MID TOWER 6/7BAY ANTI-THEFT CABLE LOCK (00619109300012)
Gateway e series desktop - power light is on but computer isn't.
I turned off my gateway e series desktop pc this morning. When I came back to it this afternoon, the power light was still on but the computer wasn't running. When trying to turn the unit back on, there is simply no response. First time having this issue. Appreciate your help. Thanks.
  • 1 more comment
  • dougnorwood6 Jan 24, 2009
    No sounds at all...that is what is strange. All connections are solid, power strip is working. I've logged on and off the same way I always do. Again, the light on the power button is on, but absolutely no reaction from the tower when I push. I've executed a power cycle, unplugged everything, turned off the power strip, turned it back on, re connected all cords, etc. Still nothing. One friend suggested it could be the power supply or mother board and recommended taking the cover off and blasting it with compressed air. Hope you'll have some suggestions. Thank you very much.
  • rgerard Feb 16, 2009
    Power light was on but computer would not power up. Turned off power strip and when it was turned on there was no response or light from the power on button.
  • DEKR
    DEKR May 11, 2010
    do you hear any sounds like the fans running etc
    have you made any changes
I have the same problem i don't think its the power supply... my power see if your power supply has a "test button" on it and see if the fans work when you press that button
Posted on Feb 08, 2010
    Genius:
  • Gateway Master
  • 1,102 Answers
Don't do what your friend suggested
it won't help if you blew the power supply.Which i think you did
when power suddenly goes off your4 supply can be burned out
if you are getting know sounds then thats what more then likely happened.
My suggestion would be to remove the power supply take it to a small pc repair store they'll test it for you on the spot.
Most new supplies cost around 40.00
Posted on Jan 24, 2009
Manual power supply
I would like you to click on this,
http://support.gateway.com/s/Manuals/Desktops/8508951.pdf
The above is a PDF file.
Checking Out Your Gateway E-4000 Computer.
Reason for manual?
There are Three form factors for the Gateway E-4000 series of Desktop PC's;
A) 4-Bay Small Form Factor (SFF)
B) Micro Tower
C) Mid Tower
The above manual covers all three, and also details pictorially, with instructions, on how to replace the Power Supply.
After the file has downloaded, go to the Bookmarks menu to the left.
Click on the + sign to the left of - Adding or Replacing Components.
Now click on the + sign to the left of the form factor of desktop computer you have.
Scroll down a little, and click right on - Replacing the Power Supply
IF, you have ANY problems, come back here, and state so in a Comment. I will gladly guide you.
(Power cables? Where they go? Etc. )
Regards,
joecoolvette
Jul 24, 2012 | Gateway E-4000 PC Desktop
When i turn on it goes start to pc entering power saving mode
Are you sure it isn't the monitor entering powersave mode?
An unhooked monitor (especially flatscreen DELLs ) will go into powersave mode if it isn't getting a signal but is getting power.
First unplug and then replug your monitor. Both ends of the cord, the end in the back of the monitor (if it comes out at all) and the end that plugs into the computer.(unplug it from the wall first)
Reboot computer.
If that fails...(and you do have a video card)
Unplug everything from the computer, open the box, ground yourself by touching the metal frame of the computer case and reseat your video card....you may have to undo one screw to get it out.
DON'T drop the screw into the case!
Put it all back together and try again.
If that all fails Boot Windows (windows right?) into safe mode and change the power settings for the monitor...perhaps something got changed or broken by an update.
If that fails....
Get Linux.
TickMagnet
Aug 17, 2011 | Gateway 505GR PC Desktop
My computer died and won't turn back on.... when i press the power button i get the power led light for a split second then it goes off... nothing else turns on such as the fan or hard drive... it will not
This sounds like a power supply failure inside of your desktop.
If you're good with a screwdriver, you can order a replacement power supply from Gateway and replace it yourself or you can take the desktop in for service.
On the Gateway web site support page, it provides you with all of the equipment installed within your desktop including the part numbers of the power supplies used.
The power supplies listed are:
Power Supplies
grn_arrow.gif100889 - 300-Watt Power Supply
grn_arrow.gif100929 - 300 Watt Bestec Power Supply
grn_arrow.gif103563 - 300-Watt Power Supply
Dec 26, 2010 | Gateway GM5072 Desktop PC
How Do I remove the cover from a Gateway 500 series???
Like this Gateway SE?
http://support.gateway.com/s/PC/2800071/280007101.shtml
On the back of the computer remove the screw from the top middle.
Now remove the screw on each outside edge, down towards the bottom.
Hold the outside shell, or computer cover. Push the inside forward.
The computer cover comes off like a shell, or bonnet.
http://support.gateway.com/s/PC/2800050/280005003.shtml
If this is a reference to a Gateway 500X series, remove the thumb screw/s from the back of the computer, on the right side. (Right side as you are facing the back of the computer) Then slide this Side Panel towards the back of the computer.
Regards,
joecoolvette
Dec 19, 2010 | Gateway 500 X PC Desktop
Computer won't turn on at all
I think ur power supply SMPS inside the systemneeds to be replaced...
Jan 03, 2009 | Gateway GX7018E PC Desktop
I can not turn my computer, laptop, on. I turned it off last night. It received uploads on Windows XP. this morning it will not power up. The battery lights are on, no fan, no blinking hard drive, and it...
the updates may not have anything to do with the issue. Unplug it and remove the battery for several minutes Plug it all back in and try again.
Robert
Sep 01, 2008 | Gateway Computers & Internet
Can not get internet on gateway e-series regular ethernet card won't fit
when you plug that wire in you should see a green light, if not then your ethernt adapter is probably bad or there is no signal coming from your wire
Aug 31, 2008 | Gateway GT5220 PC Desktop
Computers & Internet Logo
617 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
