Question about Jensen VM9510 Car DVD Player
I'm getting frequency noise
When the car is running i get frequency noise in the subwoofers. the noise is also in the front and rear rca outputs
  • 14 Answers
This happens whe you runn your rca wires to close to your power wire for your amp. you have to run the rca's down the one side of the car and the power down the other side. that will fix the problem
Posted on Jan 24, 2009
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
Hi i have just bought a alpine dvd headunit the 105r and it only has 1 phono sub output and not the left and right phono output how do i connect my amp to this
it has 3 pairs of rca outputs, one pair for the front, one for the rear, and another for the subwoofer. the other sub preamp output is not needed to run to your amplifier.
For better sound quality, buy an RCA Y splitter cable (single male connection to double female connections), and run your regular pair of rca cables to the amp.
Nov 03, 2010 | Alpine Car Audio & Video
I want to hook up subs and a amp in a 2008 saturn vue how do i do it
If you are planning on using the factory stereo you will need a line level converter. You basically connect two of your speaker channels to the line level converter. That in turn will give you a line level out (RCA cables) That line level out can be fed to a two channel amp which would be where your subs would hook up to. If you do this however you will lose two channels of mid range and highs ( your rear speakers ). Downfall to this approach is that some line level converters are susceptible to alternator noise.
If you have an aftermarket deck this will be much more simple. You simply run your RCA outputs from your deck to your external amplifier. Aftermarket decks typically have front rear and subwoofer outputs. That means you can drive a four channel amp for your front and rear and a two channel amp for your subwoofer. This is the recommended way to go.
For hookups I just suggest buying an amp kit that is comparable in power rating to your amp. If you buy a 500watt amp make sure your wiring kit can handle at least 500 watts.
Feb 12, 2010 | Jl Audio M5122.4 Diamond Audio 12" Car...
What is the wire diagram for the 3way bx35 boss crossover
Hello rew_smith,
The wiring diagram is silk screened right on the top of the unit. If your diagram is missing or obscured, you can get one directly from www.bossaudio.com.
The first 3 pairs of connections for subwoofer, front, and rear inputs coming from your receiver or head unit. Top is left channel, bottom is right channel. The 2nd set of connections are the outputs and matched in function to the first set. These are connected to your amp(s).
To the right of the input/output connectors are the 12V +, remote and ground screw terminals. The 2 switches and 9 controls allow you to set the high-pass frequency and output levels for the front and rear channels, and the crossover frequency, bass boost, phase, and output level for the subwoofer.
Hope this helps.
Aug 23, 2009 | Boss Car Audio & Video
Rockford fosgate 3002 thermal light on no sound
Is this powering speakers or subwoofer? If it's the subwoofer you need to make sure the gain is turned up and the sub is set to low pass frequency. Also make sure bass and subwoofer are enabled on the head deck. Make sure the RCA's are hooked up properly at the back of the head deck. If it's the speakers then you may have balance set to front only so your rear speakers aren't making noise.
Aug 04, 2009 | Rockford Fosgate Car Audio & Video
Do not have a sub output on receiver /do not know which wire to plug into the amp sub input/5 channel amp /have rca output for front and rear speakers
Hello southernbike,
With a 5-channel amp (stereo L/R front, stereo L/R rear, and subwoofer) you only need the two pair of stereo inputs.
You do not say which brand and model of amp you have, but most have an output configuration similar to the Alpine shown in this link. Connect the front and rear RCA's from your receiver, your vehicle speakers to the respective output terminals, and your subwoofer to the 5th channel terminals.
Hope this helps.
Jul 29, 2009 | Dual Car Audio & Video
How do you hook up a sub and amp to a stock radio with NO RCA outputs?
you can splice into the wires for your rear speakers and install some of your owns rca's and just use the low pass filter on your amplifier to eliminate the mids and highs from the frequency to your subs.
Jun 24, 2009 | Kenwood KSC-WD250 Car Subwoofer
I have a kenwood head unit with 3 rca outputs,front,rear and sub.my crossover is a kicker kx3 and it only has front and rear in and front,rear and sub out.my question is how do i hook up the crossover...
No. I would recomend running front and rear to the crossover. Use the sub out on the deck so you have total control of subwoofer output at your fingertips. Your deck should have at LEAST an 80hz crossover built in. Any further fine tuning can be done at the sub amp.
Larry T
Winona Lake,IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 28, 2009 | Car Audio & Video
No remote from Cd player. What to do?
thats a car dvd player right what u would do is to take the back of the unit and look for the female ends of rca's on the unit that they will say rear out put hook them up and run them to the amp and i dont get what u mean about the remote wire but let me no if that helps
Apr 04, 2008 | Jensen A600HLX Car Audio Amplifier
Cerwin vega ht-10d subwoofer won't work in yamaha reciever
Well, as I know, your Cerwin Vega subwoofer is designed for use with stereo systems. Therefore, it has only 2 channels for input, and 2 channels for output as well. However, you can try this out; the first thing I suggest is that you hook up your main front channels through the subwoofer. All you have to do is to connect the subwoofer input to the front channel output on the amp, then hook up your front speakers to the satellite output on the subwoofer. As long as you make sure that system is working on 8 ohms, I believe this can activate the subwoofer.
Sep 15, 2007 | Athena AS-F1 Main / Stereo Speaker
Jensen VM9510 Car DVD Player Logo
43 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
