Question about HP Pavilion Computers & Internet
Continually reboots When I turn on my HP Pavilion G6 it stays on for a few minutes then states "Your PC has encountered a problem and must restart". It keeps doing this. This problem just started. It is a new computer with windows 8 and I can't find anything on the thing.
    Problem Solver:
  • 15 Answers
Bring it back if you can. If not and you have the windows 8 disk try rebooting make sure you have the produce key password. if you don't have any of that try a system restore its in your control panal
Posted on Jan 17, 2013
SOURCE: my hp notebook pc keeps on shutting down every 10 minutes or so
Check out HP's web site regarding an Enhanced warranty program for specific laptops. My DV6113us had a problem with it restarting and it was one of the model numbers covered. Bad Motherboard....
Posted on Mar 14, 2009
myrlex
  • 674 Answers
SOURCE: I have a hp pavilion dv6000, when I start the
there are alot cause of blue screen and auto restart,,1. some part damage or bad, 2. Operating system damage,3. if you installed some program not compatible in each other files system..
To Do....
chech the hdd..2. use another hdd, if the same, remove the cd room drive. use external cd or dvd room drive..
Posted on Jun 06, 2009
  • 121 Answers
SOURCE: My HP pavilion tx 1000 keeps rebooting it self
scan your system for viruses if this doesn't solves the problem then try replacing the ram or check it using memory diagnostic tool
if every thing above is ok
==> reinstall operating system thats it
Posted on Jul 09, 2009
  • 123 Answers
SOURCE: HP Pavilion dv9700 black after closing lid.
when you changed it to do nothing on battery or power did you save these settings........I know it is a silly question but it sounds like the laptop is going into Hibernate mode
Posted on Jul 31, 2009
Damilare
  • 358 Answers
SOURCE: My laptop - HP pavilion the laptop turns on but
Hello Melissa,
Sorry about the problem.
I will try as much as possible to give you a detailed steps you can try out.
And they are going to be in two Options.
First options is this:
Put on your Computer,
While it is booting, Keep tapping the F8 Key, and this will bring up the Menu where you will have to
select the different options of booting.
First of all try out "Last Known Good Configuration".
If it doesn't work, then try booting into safe mode.
If it boots in Safe Mode,then do these:
First, open my computer,
right-click on your hard drive, and select properties,
then select tools tab, then under the tools tab, you should see error-checking,
then click on "Check Now", then select the tabs under this and click on start.
It will tell you that it will be done at the next system restart, so click on OK, and restart your system.
Next, Defragment your hard Drive, by going to Start--->All Programs-->Accessories-->System Tools-->Disk Defragmenter.
All these things are going to take you a lot of time to finish but I'll tell you the truth...they are worth it.
After all these, you can now (optionally) improve the performance of your system by going to this place :
Right-Click on my computer, Properties, then Click on Advanced, then under the performance tab,
click on settings,
and select 'adjust for best performance'.
This will change the appearance of your system and significantly increase your system speed.
If it doesn't boot into Safe mode, then go to this next one:
Select Safe mode Command prompt.
When you get to command prompt, type: chkdsk or chkdsk /f , and press enter.
This will scan your system for errors and correct it.
In case it is as a result of a hardware problem, try this:
Get a screwdriver, unscrew your laptop at the back where you have a symbol of RAM(Memory) drawn,
If you can't do it by yourself let a technician do it for you.
Remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
if the two of them works, them insert the them all.
but if it is just one that worked, just remove the other one that is not working and replace it.
If Trying All these does not work, then Go to this next option.
If you have a Windows Installations CD.
Insert it into your CDROM Drive, then when you put on your system,
Go into the system BIOS/Setup by pressing 'Del' key or any other key (e.g F10 for HP PCs) required to enter setup while the system is booting.
Now look for where you have Boot Sequence or Boot Order.
Select the CDROM to be the one where the system will boot from,
then follow the On-Screen instruction and select repair.
(Which means you will have to get a Windows Installation CD.)
All these are the FULL trouble-shooting steps you will need to get your system working.
But if after trying all of them out it still does not work,
Then you will have to take the system to a good technician.
Kindly keep me posted and let me know how it goes.
Thank you for using FixYa.
Good luck
Posted on Jan 03, 2010
HP Pavilion G6- Hdd upgrade
Try inserting Windows installation disk to see if it detects the disk in the setup. Otherwise check the sata connectors or the motherboard compatibility
Jul 21, 2015 | HP Pavilion Computers & Internet
Certain keys on my numpad not working.
In that case I would suspect the keyboard as the keys are grouped together in one multiplex.
Jan 15, 2014 | HP Pavilion g6-1a50us 15.6in Widescreen...
Need owners manual for hp-g6-1d62nr laptop
Get onlineand got to www.google.com In the google search box type: "PCSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and Documents.
Apr 14, 2012 | HP Computers & Internet
My HP e9120f gave me the following error message the other day. "reboot and select proper boot device..." My first thought was my hard drive was bad. I could turn off the computer and after a...
You might have another part that has gone bad. Check the RAM and see if it gives you any problems.
There is a program call mem test that you can burn to a CD and test your memory. But if your no longer able to get to the bios:
you def had a hardware problem.
May 04, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
At the login I received this error message "cannot
Ignore for time being if possible and logon a few times as is. Reboot a few times as is. If still a problem try cmd as admin and use "netsh" "reset winsock" cmds
Dec 27, 2010 | HP Pavilion Elite M9060N PC Desktop
The cd drive continually pops out
It is prbably a bad cr drive. HP has extended the warrnty on many of those laptops because of issues such as yours. read the info on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 27, 2009 | HP Pavilion dv6000t Notebook
My HP pavilion tx 1000 keeps rebooting it self over and over. I reinstalled the System Recovery DVD and it turn on for a few minutes and the reboots itself
Jul 09, 2009 | HP Pavilion tx1000z Notebook
Pavilion dv 1000 won't reboot, stand by nor turn off
I had this kinda problem solved on a Acer 5920 LAptop. The webcam driver was the culprit. Remove the cam driver for the same, the windows driver will take over and then i guess it will work fine. I figure its a driver issue or a TSR program not quitting. If this fails try uninstalling recently addes program or driver.
Jan 05, 2009 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
35 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
