Question about Toro Ccr Snowblower
Any ideas for why a brand new toro 38025 belt slips off??
I have a brand new toro snowblower model 38025 that has a main drive belt that keeps popping off. Thinking the belt was bad I bought and replaced it with a new one and it also slips off. I can't see any misalignment between the 2 pulleys and the idler arm appears to push up against the belt evenly. What else can it be?
5 Suggested Answers
SOURCE: i have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Posted on Jan 08, 2010
Testimonial: "Thank you for the quick response."
barterjoe
  • 338 Answers
SOURCE: toro model 38182 replaced new flat idler gear belt
It sounds to me like your idler pulley pin is bent. The Toro part number 75-872. You can order it through a shop like www.arcolawn.com and have it shipped to you in a day or two.
Please vote my fix up if it helps.
Joe
Posted on Feb 12, 2011
01fordeb
  • 1033 Answers
SOURCE: My TORO 14-38 ride on
The pulley should turn, sounds like the bearing are froze up.
Posted on May 29, 2011
roberthig924
  • 30 Answers
SOURCE: how to replace drive belt on toro recycler
First thing you need to do remove spark plug wire.. Then I would go to the website for Toro have the serial number ready there you will see the full picture of the way it is then go from there that's the best way with out seeing it. Good luck
Posted on Sep 16, 2012
How do I adjust the belt ona Toro 726 snowblower
There should be a tension pulley between the main pulleys. Usually it is mounted on the side wall and can be adjusted with a nut and bolt.
Mar 16, 2016 | Toro Power Max 726 OE Snowblower - 37771
How do I replace a Toro mx5060 drive belt?
First, jack up rear end and support with jacks and ramps. When u first look you will see the first step is to drop the blade belt. Next reach up around the main drive pulley and disconnect the wiring plug by popping up the latch. It may be a tight fit for someone with big hands. Next you will need to separate the stabling plate and move to the side. You will need to remove the tension spring to loosen your small tension pulley. You should inspect your pullies for wear, I had to replace them too, especially the plastic one. You can now apply your new drive belt. Make sure you apply the belt properly or it will just chew up the new belt. It took me two belts to figure that out. You can download a diagram at toro.com. Re-apply your tension and replace all parts in the order you took them off, making sure the wiring adapter is securely in place. Try and start the more and check belt observing safety rules.
Jun 21, 2014 | Toro TimeCutter MX5060 50" 23HP Lawn Mower...
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
Toro 521 snowblower instruction to replace belts
Remove bottom cover(4bolts) 3/8"Remove plastic housing cover (mine had 2 bolts)3/8"Loosen belt guide bolt.1/2" rotate guide away from belt.I used a pipe wrench to hold main shaft and removed drive pulley.Replace drive belt as you return pulley onto shaft.Replace auger belt.Align belt guidesSet handle adjustmentsReplace coversTest and hope for warm weather, I live in BuffaloHope this helps
Jan 01, 2011 | Washing Machines
I have a toro ccr 2450 snowblower. i bought it
Sam
Jan 08, 2010 | Toro Lawn Mower With Toro Power Tools
Snowblower drive will stop unexpectly when snowblowing
Mine was doing the same thing and I found that if I put it in reverse for a little while it would be ok again for a short time. I found also that it did this more often when the snow was heavy and wet which makes me think that the rubber drive wheel is getting wet and slipping. If you've brought it in to a shop and they've said that nothing could be found wrong, then it must be something that goes away by the time you get it there - water (I'm guessing).
Feb 28, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Toro Ccr Snowblower Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
