Toshiba Satellite A105 Notebook Logo
Posted on Jan 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba A105 will not boot up even with cd and f12
My toshiba A105 will not boot up..i can hear the windows startup music but nothing else. I have tried the restore cd and holding f12 on boot up but nothing still. any ideas?
Anonymous
Level 2:
  • Expert 43 Answers
  • Posted on Jan 24, 2009
Anonymous
Expert
Level 2:
Answers
43
Questions
0
Helped
13426
Points
154
Its not a booting issue if you hear the music, it loaded windows. you might have a display issue, shine a light on it to see if you can see any faint images, if you can the backlights out if not it might be the display adapter on the MOBO, in either situation calling toshiba would be required for a repair, or otherwise take it into a shop, but first try a power reset,
unplug it and remove the battery, then hold the power button down for one minute, replace the battery and power cord and try to boot again. if this fails call toshiba, its definately a hardware issue.
My cd rom is working fine. It is able to burn files also with win7 software. I want to repartition and reinstall the software. System does not boot from cd. I even changed the bios where all the three...
On some models this prompt reads Press F12 for boot menu. On others, it may say Press C to boot from CD-ROM. On still others, there may be a row of colored icons representing the various boot devices (HDD, FDD, CD, LAN, PCMCIA, etc.) Press F12 while these icons are displayed, and then use the arrow keys to move the cursor from one to another. As new models are released, the wording of these prompts may change.
Immediately after pressing the power-on button, press the hotkey for the device from which you wish to boot:
HotkeyBoots from deviceCIDE CD-ROM1FISA FDD2UUSB FDD3Ninternal LAN adapter4
My a105 s2712 will not boot from a disk. I followed all instructions even from tech support and it will not do it.
If the disk is a CD or DVD, you should carefully inspect its surface and if there is any dirt or fingerprint smudges, carefully clean it. A bit of hand soap with water and a soft non-lint tissue can be used to clean. Be sure to wash all traces of soap off and using a soft lint-free tissue make sure disk is dried before re-inserting into the CD/DVD drive. If inspection shows the disk to be scratched, you may try a disk resurfacing kit but this may not be sufficient to return the disk to a bootable condition. Presume your tech support instructions have covered using your notebook's setup/startup to verify the boot devices being looked at on startup and their order. You may want to set the device with the problem disk as the first and only boot device to eliminate any possibility that one of the other boot devices in the startup list is interfering with subsequent boot up of the problem disk.
Toshiba satellite m35x-s114 boots to the toshiba screen then doesn't do anything else. Even with the f2 or f12 option nothing happens. I hear the fan (I think it is the fan) then no sound at all. I have to...
Try getting to the bios screen, if you can get to the bios screen then I would imagine the hard drive has failed. If it is hanging up at the toshiba splash screen and not allowing BIOS access, then I would lean toward a motherboard failure. Are you attempting a boot from the windows disc?, is that why you are trying F12? I have seen my share of these Toshiba M35's just give the Toshiba splash screen when there has been a motherboard issue. Changing out the main board will fix this particular problem. I had not found another solution for it.
1helpful
TOSHIBA Satellite A105-S4004 doesn't boot
unfortunately older models such as the a105 do not have a recovery partition. however recovery cd's are around 25 dollars if you contact toshiba directly
2answers
Toshiba A50 Not able to boot from CD
When you load the cd and reboot, when you see the toshiba screen, start tapping F12, see if this brings up the temporary boot menu, if it does choose the cd and watch closely for "press any key". If there is nothing showing, might I suggest you get an external cd drive that attaches by usb. You will then have to get back to the BIOS and set the usb as your first boot device and try to boot again from the usb cd drive. Good luck.
2answers
I would like to reset my computer to the day I bought it.
OK, you need to locate to system CDs that came with your laptop. One of them will be disc 1 or operating system or Windows CD. Insert into the CD ROM drive. Power up laptop and when "Press any key to boot CD.." is displayed, press any key on the keyboard. If this message doesn't display, then the CD will boot and just follow the on-screen messages to install your OS. If your laptop doesn't boot the CD, then you need to go into your BIOS and set the CD-ROM drive as the 1st boot device. Follow on-screen messages during boot-up to enter your BIOS or try pressing the DEL or F1 or F2 or F12 key while powering up your computer. If you do not have the system CDs, then you need to call Toshiba and order them.
2answers
Computer will not boot
let me know r u able to login in safe mode?
Toshiba Satellite A105-S2141 Lockup
Have you checked the heat of CPU? It might be cause of CPU overheating.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
