Question about Konica Minolta Office Equipment & Supplies
Konica copier had a double image
A friend of mine made copies on a Konica copier. Later another employee used this copier and some of the information my friend copied appeared as a double image on the other employee's copies. What made this happen?
  • Konica Minolta Expert
  • 414 Answers
Your fuser unit is worn out
Posted on Jan 15, 2013
Cogz
  • 1326 Answers
SOURCE: Canon NP 6050 Copier - number of copies
I would say that is not the correct meter. The meter is only 6 digits long, maybe 7 it's been awhile scine I looked at one. You probly have a meter of 0136012. There is only one hard counter / meter in the copier. It's not even the serial number?? Good luck
Posted on Apr 30, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Konica 1015 copier with image ghosting problem
I hope the correct toner is in there.
It could be that the cleaning blade on the drum isn't working or the charge isn't working right.
Posted on Sep 17, 2008
  • 16 Answers
SOURCE: Canon NP 6218 B&W Copier
try also to change or to service the corona units both the upper corona in the drum unit and the the transfer corona assembly unit down the drum. ok try your best.
Posted on Oct 02, 2008
  • 18 Answers
SOURCE: copies have ghost image
yes. although I would first check the fuser unit. It is located the exit side of the copier. let the copier cool down before handaling the teflon fuser roller. The upper roller has a teflon coating, if it is worn the image will not transfer properly to the paper thus leaving a duplicate / ghost image. Good luck
Posted on Nov 26, 2008
SOURCE: Konica 1216 copier makes black dark copies
dear sir i have information P 27 on my konica copier. how do i solve the problem..?
Posted on Sep 07, 2009
KONICA 7272 CODE SC49-01
Image processing board failure. I would first check all the connection on the image processing board pull each connector one at the time and check for a bent pin, worse case the image processing board is bad, doubt you can find one a Legacy Konica Machine Konica is now KonicaMinolta.
Jan 21, 2015 | Konica Office Equipment & Supplies
Konica minolta bizhub c451 imaging unit chip non stop dut not take print
REplace the image unit properly no not chip cause image problems later
Jun 20, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
I HAVE Konica Minolta Konica Minolta C550 .WHEN I USED COPY OR PRINT EXITING PEAPER IS DIRTY OR HAVE BAR BLACK. PLEASE GUIDE ME
"Dirty" could be one of 3 things... Transfer belt, Imaging unit and fuser unit. Make 5 copies in jam the machine by opening a cover. remove pages and see where the "dirt" originates from.
Jan 08, 2014 | Konica Minolta bizhub Office Equipment &...
Cof32, blank copy on printing and copying bizhub c350
C0F32 is e developer problem,Imaging Unit ATDC (automatic toner density control) failure.
Try to add some toner and adjust the developer.
Enter service mode and adjust with F8
Apr 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Color Copies - double image
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 10, 2009 | Konica Minolta bizhub C250 All-In-One...
Sep 17, 2008 | Office Equipment & Supplies
Konica Minolta Bizhub 7235 copies curling at exit. Single or double sided from Document feeder curl almost to the size of a paper towel tube/core
dear friend:1-check the paper and use fresh paper out of wet and stored in dry place.2-use cooling oil and replce oil cartidge in the heater section.3-replace silicone roller (the lower roller in the heater}4-check for smoth movement of exit section(gears-chain-rubber belt}in a good condition replace any defective part.
Feb 20, 2008 | Office Equipment & Supplies
Double imaging on a sharp small copier
Check the drum cleaning blade.if it is ok check the fuser roller.
Sep 21, 2007 | Office Equipment & Supplies
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
