Question about Toshiba 50A62 50" Rear Projection Television
Remotes do not work
Have 2 50A62 Toshiba sets the remotes will not operate them battiers are good
they did work them some time ago
the remotes from Dish network can't find the proper codes to work them
remotes bad?
or IR Sensor bad ?
both sets?
    Guru:
  • 416 Answers
You can quickly test the remote in question with a digital camera... please vist my Tips & Tricks so see how.
Posted on Mar 16, 2010
How do I program the Toshiba CT-90325 remote to control the Toshiba SD-V280 VCR/DVD player?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 23, 2014 | Toshiba Original CT-90325 TV Remote...
My remote controll just stop working i have changed the battiers 3 times still will not work
Look at the front of the remote control with a digital camera or the camera on your mobile phone and press the buttons on the remote. If you see a bright light then the remote is working and the problem is with your TV.
Feb 28, 2011 | Soyo SYTPT3227AB 32 in. LCD TV
Front Display is saying DR-2 and will not let me use remote to control anything...only thing I can do is shut power off with front panel..I have unplug from outlet and let set for 30mins and plugged back...
I received an attachement from the Toshiba Repair folks several months ago, when we had the same problem. To resolve it, do the following:
While pressing the Easy Navi button on the remote, press 2. The remote control mode will be set to DR 2, which is what the recorder is telling you it is set to.
We encountered this problem for the first time, for no apparent reason. It happened again today, after the operator dropped the remote. This fix worked both times.
Nov 07, 2010 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Charter Cable serviceman came out earlier today and switched the cable box that had been connected to a 46" Toshiba 1080/120 flat screen tv that was just set up a couple of days ago. The cable remote does...
I have the same problem with my 46" Toshiba Regza 46XV645U. I have Time Warner cable, with a Scientific Altanta Explorer 8300HD and a Synergy V RT-U64CP remote. I've tryed a few different boxes with new remotes and it still happens. The cable remote works the TV but not the box(unless I have the box turned 90 degrees). Once I turn the TV off the remote starts working(from what is can see on the display).
I can't program the TV remote to operate the cable box either. I think I need a different model cable box or maybe flash it or something.
Jun 26, 2010 | Televison & Video
Biiig problem
Be very carefull with your remote it does alot more then just turning on TV you have to have it to Get into Service Mode in the event you need to repair TV! Have you replaced Battiers
Nov 12, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
May 04, 2009 | Toshiba Televison & Video
My ford fiesta central locking doe es not work
first is it remote or key operated
if its remote operated try changing the battier in the key
if its key opperated try useing the other front door if it works from that side its the pick up sensor on the lock at fault
Jan 06, 2009 | Ford F Cars & Trucks
Programming my toshiba universal remote
http://www.tacp.toshiba.com/tacpassets-images/models/27AF45/docs/27AF45_om_E.pdf
Scroll down to the remote section page 12 -13 its in there... I have this same remote and just programmed it.. Good Luck to you!
Oct 12, 2008 | GE 84918 Remote Control
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Remote Control in Hampton Bay Windward II
Hello Allez Brive. A suggeston, remove the battiers and short out the battery contacts. insert new battiers with correct polarity and test operation. The age of your remote maybe the problem. Good luck.
Sep 17, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Toshiba 50A62 50" Rear Projection Television Logo
133 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
