Question about LG WD-3243RHD Front Load Washer / Dryer
Lg wd-3245rhd LE error message
LE error message, motor overload
  • LG Master
  • 17,129 Answers
This seems to be a fault in the motor wiring harness, check all the connectors to and from the motor, check the male and female connectors. Also check the sensors to the motor which can cause this motor to show up as overload.
Posted on Jan 15, 2013
4 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: Error code LE on front load LG washer
This is a motor fault code. Sometimes it can be just a communication error, in which case you can try unplugging the machine for 20 minutes and see if it clears the problem up. More likely it is a fault in the motor itself. The most likely culprit would be a defective hall sensor. I will attach a photo of the sensor for you to see what it looks like. To access and replace the hall sensor, you have to remove the rotor and stator at the motor. Before going to this trouble, try the unplugging thing first and also check the connector on the main control board. It is the red connector next to the heat sink2.gif. Using a multimeter, check that the board is receiving a signal from the sensor. Hope this helps and best wishes.
Posted on Sep 02, 2009
taran_2005
  • 10515 Answers
SOURCE: 5 year old LG WD-1219BD has error code LE, ''overload in motor''
LE is a very bad error unfortunately. It means that your motor communication is being lost. Generally on these LG washers it means that you need to replace the motor sensor. You will have to take the back panel off so that you can access the motor, remove the pulley and take the motor off, there is a little plastic sensor that clips onto the edge of the motor. The sensor is not sold separately from the motor so you will have to replace the motor unfortunately.
Part would cost you around $120 plus labor.
This is a common error on LG. Better to repair and use it or fix it yourself.
Hope i helped you,
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 11, 2009
Testimonial: "Thank you Guru. Your advice was spot on what I needed to know and has assisted me greatly. Thanks again!"
  • 121 Answers
SOURCE: drum will not spin
You will need to change the rotor and stator,
Posted on Jul 21, 2010
When i plug washer in,cl displays on screen and machine will not turn on.
There is no "cl" error code for the LG WD-3245RHD. Your display unit may be bad, because there is a "cE" error code, which indicates an overload in the motor, and the suggestions in the manual are to close the tap, unplug the machine and call a service technician. So far, I have been unable to find anyone that will adequately service any LG appliance. It seems they think of their products as disposable, not repairable.
Oct 29, 2010 | LG WD-3245 Front Load Washer / Dryer
Hope i helped you,
Oct 11, 2009 | LG WD-1295FB Front Load Washer
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
LE error message - how to finish the wash cycle?
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Jun 17, 2009 | Washing Machines
LG WASHER WM1832CW HAS LE ERROR MESSAGE
Jan 15, 2009 | LG WM-2277HW Front Load Washer
Lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Mar 17, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG washing machine Model WD 1433RD
I had the same problem. I thought it was the motor it turned out I had a nickle wedged in the filter (bottom left behind panel) the nickle blocked the water pump makeing the pump overload.
Sep 15, 2007 | Washing Machines
LG 1285
Lg washers used to carry a 3 year warranty.check warranty as requires a new stator.
Jan 05, 2007 | LG WD-1280FHD Front Load Washer
LG WD-3243RHD Front Load Washer / Dryer Logo
143 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
