Question about NewAir ACP-1400H Portable Air Conditioner
Have a Newair 1400H air conditioner that has never been set up. Need operations manual.
4 Suggested Answers
  • 615 Answers
SOURCE: The Newair acp 1400h puts out a lot of heat and
The longer hose will increase the heat in the room and that is why they recommend the short hose…addition to that it may overheat…if you are going to extend the hose you must use one as the dryer hose that insulated and fire proof…let me know if that help
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Posted on Sep 17, 2009
  • 4736 Answers
SOURCE: Could you tell me someone
If you cab salvage a few parts, you won;t have to purchase an entire new vent kit. You can find similar vent hose at any home center in the heating and cooling dept. Just take a piece of your old vent hose with you and match it up to one that same diameter. You can use your old termination and connect it to the new hose. You can do all of this fairly inexpensively.
Hope this helps and saves you a few $$ at the same time.
Posted on Apr 19, 2011
heinzhvac
  • 229 Answers
SOURCE: My NewAir ACP-1400/H air conditioner freezes up. I
Its sounds like a refrigerant leak from the factory if you just got it. Check your warranty and call the manufacturer for repairs. Unfortunately there is no simple fix.
Posted on May 17, 2011
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
Code error E7
I'm not sure if NewAir is made by Gree -- they supply many. On Gree units, E7 simply means one unit is requesting heating while another is requesting cooling and you can't have both at the same time. So that's the first thing to check. Very simple, very common, doesn't indicate that anything is wrong with the system.
Apr 05, 2014 | NewAir ACS-1200H Split System Air...
I have a New air 1400H and the blower fan has broke, can you tell me where to find replacement parts for this unit? I understand it has been discontinued for almost 5 years. Thanks for your help.Cont
You may have to remove the complete blower assembly, remove any dead squirrels, and take it around to various appliance parts suppliers to obtain a suitable replacement. You may need only a replacement motor if the squirrel cage is intact
Apr 30, 2013 | NewAir AC14000H Air Conditioner
Need to locate a operations manual. Moved into a house that has unit but no instructions
Could this be what you're looking for: http://www.newair.com/manuals/newair-ac-14000h.pdf
Jan 14, 2013 | NewAir ACP-1400H Portable Air Conditioner
NewAir AC-14000E not blowing ice cold air
Unfortunately there can be several reasons for your AC-14000E portable air conditioner not cooling well. As with most portable air conditioners the filter grates on the rear of the unit can be removed for cleaning. When those are removed you may be able to clean some portion of condenser coils. There is also the possibility that your portable AC has a refrigerant leak in the system and will not be able to cool effectively without a repair (which usually costs as much as a new portable AC). Portable AC's are not designed to be recharged and operate on a sealed refrigerant line so even finding someone able to repair it may be a challenge. Your best bet is contacting the company you bought it from and talking through some solutions, they most likely have experience with these units and should be able to help you.
Jul 10, 2012 | NewAir Heating & Cooling
My NewAir ACP-1400/H air conditioner freezes up. I have cleaned the filter and check the air flow. Everything seems good, but it still freezes up.
May 17, 2011 | NewAir ACP-1400E Portable Air Conditioner
Water full light wont go off even after water drained
There should be some kind of float switch that senses water level. It sounds like it's stuck.
May 02, 2010 | NewAir ACP-1400H Portable Air Conditioner
The Newair acp 1400h puts out a lot of heat and the manual says not to extend the exhaust hose. Is there any way to extend the hose so that I can exhaust where I want to?
Sep 17, 2009 | NewAir ACP-1400H Portable Air Conditioner
Not blowing cool air
Likely needs freon has leak needs repair local hvac contractor can help. T
Jun 16, 2009 | NewAir ACP-1600H Portable Air Conditioner
NewAir ACP-1400H Portable Air Conditioner Logo
Top NewAir Heating & Cooling Experts
gbob59
Tom Chichester
Bill Boyd
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
