Question about Olympus Camedia E-20N Digital Camera
Flash drains Li-Ion rechargeable batteries instantly
I have 2 LB-01-equivalent rechargables I purchased on eBay severl months ago. I can shoot about 30 minutes of continuous exposure in bulb mode with these batteries. However, if I flip the flash up, the camera goes black after a few seconds, and I must re-charge the batteries. I do not have this problem using NiMH batteries, but I can't shoot for nearly as long in bulb mode. What gives?
  • 1 more comment
  • Chris Williams Jul 10, 2007
    I can usually get a hundred or so photos shooting without the flash during normal use.
    THe long exposures are for astrophotography.
    For astro-photography I use an 18 Amp-Hour 12V battery. (It is designed for emergency jump-starting cars, but has two power outlets for 12V devices.) I reduce the input voltage to 7.2 V via a DC-DC converter and connect to the DC input jack.
  • Chris Williams Jul 31, 2007
    Turns out it was the batteries. Bought some CRV3 NiMHs from Radio Shack and the problem went away.
    Genius:
  • 2,985 Answers
Inferior batteries from a dodgy site on E-bay -at a guess Sport out on some regular batteries. Shooting in brief mode I would think takes a larger whack out of the batteries than ordinary shooting I would imagine. What are the pictures of?
Posted on Jul 09, 2007
  • john ash
    john ash Jul 10, 2007
    A Hundred normal shots per charge is about normal.
    Asstro long shots I guess does mean more drain per shot so fewer shots per charge.
    But I think you problem is all most certainly 'cheap' batteries.
    I have a 2 battery holder on my E.300.
    Astro Photography- is this near a domicile ?
    Have you considered a mains converter- standard
    Multi V- to give you 6 volts would do it.[Check your manual]- I did it with my E-10.
  • john ash
    Well we are beck to duff batteries from E-bay then.
    Sport out on regular brans ans see if you can extend the life
SOURCE:
Tip
Samsung SLB-11A Battery
Batteries are very important, here has the best quality products and considerate service
Battery Type: Li-ion
Voltage: 3.80V
Capacity: 1130mAh
Color: Black
Dimension: 43.40 x 31.70 x 7.40 mm
Product Type: Replacement Battery (Brand New)
Condition: New, 1 year warranty!
Weight: 49.61 g
Inventory: In Stock
1. New Generic Samsung i8 Compatible Li-Ion Battery
2. Extra power for your Samsung i8 camera or camcorder
3. High capacity rechargeable Li-ion Battery with premium cells
4. Absolutely no memory effect so you can charge battery at anytime
5. Usually Ships Your Samsung i8 Battery in 24 Hours, 12 months warranty.
on Sep 21, 2010 | Cameras
Battery charging
Only the Li-Ion batteries designed to work with the radio can be charged inside the radio. If you have Li-Ion rechargeable batteries such as those you can buy along side the
Alkalines in a store, the answer is no. This type would need to be charged in the style of charger made for recharging this brand/type of battery
Jan 25, 2014 | Motorola Walkie Talkies 2-Way Radio
Every time I turn the camera on, it takes 2 to 3 minutes to come on and always makes me verify date and time. Why?
This usually indicates that your rechargeable Li-Ion battery is starting to lose its ability to retain adequate charge due to age and usage (about 500 charges or 18 months of 'normal' use). Try putting a new rechargeable Li-Ion battery.
Hope it helps!
Jan 16, 2010 | Kodak EasyShare V1003 Digital Camera
My Z812 keeps telling me I need to reset the date/time every time I turn it on, even if I have just done it. Also drawing batteries very quickly (lithium, camera type)
It may only happen enter date and time if you remove the battery in the camera., If your not removing the batteru out of the camera you should not recieved that message, unless battery is out of charge or no power.
You should use this battery Kodak Li-Ion rechargeable battery KLIC-8000. This is a special battery for Z812 camera,
Note: You must also need to purchase a charger for this type of battery.
I guarantee you it will provide stable longer power for on your camera
Nov 20, 2009 | Kodak EasyShare Z812 IS Digital Camera
Problems with camera
Hi everyone,
I found you because 10 minutes ago, my camera exhibited the same behavior as all yours. All of a sudden, the red and green lights started blinking on and off and nothing worked. I just tried switching batteries and the camera is working! I am using a couple of RCR-V3 Li-ion rechargeable batteries, which I purchased on Ebay three months ago. Thought I'd pass it on.
Take care,
Rosane.
Jul 17, 2008 | Olympus SP-350 Digital Camera
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Jun 14, 2007 | Kodak EasyShare C875 Digital Camera
Is the battery that comes with the camera rechargeable?
Yes, the battery that comes with the C-7000 can be recharged. This battery is the Olympus LI-12B Lithium Ion battery and it can be recharged using the LI-10C battery charger. Both the battery and charger are included with the camera.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Olympus Camedia E-20N Digital Camera Logo
52 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
