Question about Frigidaire GLTF1670A Front Load Washer
Water keeps filling
I have a Frigidaire GLTF1670A Front Load Washer. Did 3 loads fine on the 4th load I came in to find that the water was still running and would not shut off. Turned machine to off. Unpluged from wall still kept filling with water ???? only able to fix by turning water off at wall.
Please can you help.
  • 99 Answers
This is joyce:
I had this same problem happen to me I was on a well system and some trash got into my line and it got in my shut off valve that controls your water, and it caused me to have to have techn, to come to my house and fix, now if you have someone that knows how to work on the machine you can go online and download doc. go to and put in your model# and download doc. it will show you where your water valve is located on your machine. you can go to local dealer and buy this they ususally keep them in stock they are not that exspensive but they do have to be replaced when they go bad, I suggest if you do not have a water filtration system on your line to your washer get one or this will happen again. sorry.
hope things work out
Posted on Feb 07, 2009
Frigidaire gallery front load washer dripping sound
With any front load machine manufacturers suggest to leave the door open after cycles to help evaporate the water - this is even done in top loading machines nowadays. Also clean the unit with bleach water and rinse in high temp water cycles.
Aug 12, 2012 | Frigidaire GLTF1670A Front Load Washer
Washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Mar 26, 2009 | Frigidaire GLTF1670A Front Load Washer
Rubber boot keeps getting holes in exact same spot then leaks
Either its not installed properly or you have some sharp foreign object in the basket or tub
Mar 06, 2009 | Frigidaire GLTF1670A Front Load Washer
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Tub won't move
could be motor, control board, motor controler
Apr 10, 2008 | Frigidaire GLTF1670A Front Load Washer
Ftf530Es;Frigidaire front load washer
did you check the filter? If the filter is plugged in the least bit it won't allow machine to spin at high speeds
Mar 08, 2008 | Frigidaire GLTF1670A Front Load Washer
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Feb 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Washer will not spin
is the door lock lit make sure the door is closed all the way make sure the dispenser door is closed all the way their is a magnetic switch in it that will not let the washer spin if its not closed it also will not spin a small load try adding a couple of items let me know if this does it or not
Jan 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Front Loading Washer Leaking
there should be a rubber pipe going to the soap draw to the drum normally there's to pips one at the front of the machine and one on the top it is there have a good look in the machine make sure its un plugged be for putting your hands in the machine ok
Nov 28, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
76 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
