Question about Dell Latitude E6410 Laptop
E6410 does not charge the battery - Dell Latitude E6410 Laptop
  • 77 Answers
Check if in starting it is giving any error for the adoptor? if it is giving then it is adoptor issue other wise it is battery issue. May be it is also cause for M/b, so tell me exjact problem so that i can give you the solution
Posted on Feb 02, 2013
Why is my battery light staying on constantly
You mean, your laptops shows your battery is charging when charger is no connected? Is it amber or green?
How well does the battery work? Are you getting at least 90 minutes on just battery power? If not, maybe the battery is not working well. Remove the battery, turn on the computer, shut the computer off and restart the computer with the battery installed. Maybe if you reset the battery the computer will "see" the battery as new and after awhile of charging the LED should go from amber to green. While you have the battery out of the computer, check the battery contacts on both the battery and the computer. Make sure that they are clean and not corroded or damaged.
If your battery level is ok and your battery keeps it's charge, let it alone. You wouldn't like to send to repair tour laptop just for that.
Aug 10, 2015 | Dell Latitude E6410 Laptop Computer (Intel...
My battery light is staying on what does that indicate?
Battery light on indicates that your battery is charging. If charger if not connected and battery light is on, mean that something is not functoning correctly.
If your charge is ok and battery keep charge level, leave it alone - just my opinon
If you want to spend some good money, take it to a computer repair sevice
My dell latitude e6410 won't turn on When I press the power button it stays on for 3 sec them turns back off the battery charge light is on when plugged up Need help please
This usually indicates an overheating problem. Try cleaning out the fan with a can of compressed air, if that doesn't work you will need to bring it to a technician who can test the motherboard as the graphics processor may need to have solder reballing done.
Dec 29, 2013 | Computers & Internet
E6410 power adapter light off - computer doesn't start. I know, I know, already ordered a replacement power adapter, but is there anyway to fix it before then? Have urgent projects on it and have to work...
Unfortunately, no. Unless you have a spare battery that is charged, there is no way to power up the unit. If you have a Radio Shack, Best Buy or Fry's nearby they should have after market adapters available. Or if you have a friend that has a dell laptop most of the adapters are interchangeable and you could borrow it to at least get some work done.... goood luck
Oct 03, 2013 | Dell Latitude E6410 Laptop
New battery not charging
the old power supply must not be putting out enough power to charge
Jan 31, 2013 | Dell Latitude E6410 Laptop Computer (Intel...
E6410 Bluetooth randomly shuts off
The mouse is the issue, check all connections and battery contacts, if unit can run on standard battery, " replace " to see if that will help, and make sure wfi plugged into laptop properly,also try another usb plug on your laptop.
Apr 02, 2012 | Dell Latitude E6410 Notebook PC Core i7...
Dell Latitude E6410 does not connect to wireless printer
connect it by cable to your pc first to install it then remove the cable
Feb 11, 2012 | Dell Latitude E6410 Laptop
Dell latitude e6410 chargin fault ,will run on dc adapter but shows not chargin ,battery not conected
  1. If the motherboard has ever been replaced, check the service tag section of the BIOS. If it is blank, enter the service tag off the bottom of the system. (The charging circuit will not work without it.)
  2. Also in the BIOS see if the AC adapter is identified or is listed as UNKNOWN. If the system cannot ID the adapter as a Dell Branded AC adapter 90w or larger, then the charger is again disabled. If unknown, check the barrel end of the DC jack of the adapter for the fine wire in the center, if broken or bent, then the adapter is not identified.
  3. Try with a different Dell branded 90w or larger D or E series adapter.
if all the above make no difference, and the Adapter is recognized, the battery may be at fault.
http://www.fixya.com/support/r3743571-long_will_battery_in_portable_computer
if the adapter is unknown, replace the adapter, unless it works normally on another system, and the other system's adapter has the same issue, in that case the motherboard is likely the issue.
Note: a 65w Auto/Air adapter will only charge the battery if the system is OFF
Jul 27, 2011 | Dell Latitude E6410 Notebook
Dell Latitude E6410 Laptop Logo
Alun Cox
