Question about HTC Desire Cell Phone
Switch on button does not work
The phone does not always respond to the on off switch
    New Friend:
  • 4 Answers
It sounds like your on/off switch is partially broken. What feature do you need to work? Powering down? Screen off?
You can change the screen sleep settings so that the screen goes blank and not waste battery.
Posted on Jan 15, 2013
Why does my Camera not respond to several of its buttons and the shaky icon is always on?
several things can cause this including a bad ribbon cable and a worn out button pad, or just a bad switch. Time for a tech to look at it. If you're feeling froggy, open it up and replace the button pad. Canon will send you another and may not even charge you.
Jul 25, 2014 | Canon PowerShot G11 Digital Camera
Passenger unlock botton does not always respond
The switch is probably worn out. You have to take the interior door panel off to get to it. Also, most of these are an integral switch panel. That is to say you have to replace to whole panel not just the one bad switch...and you may have to get it from Ford.
Mar 11, 2014 | 2003 Ford Explorer
Some times my i phone gets switch off but when we call it doesnt says switch off but there will be ring beep.. but my i phone do not respond even if plug the charger. after 2-3 days if i charge again it ll...
That may be a hardware issue especially if you previously dropped your iPhone to the floor or got it wet. You can have a hardware expert check it to see if there's a problem with your iPhone especially those that involve your 30-pin connector below your phone. Another thing to check is the home button especially if this is the one you always push to wake up your iPhone from sleep or standby. The home button may be busted already or you're having a hard time pressing it.
Feb 24, 2011 | Apple iPhone Smartphone
What does the blue wire hook to
The blue wire always goes to Load (light fan motor)
If you have Intermatic ST01C or EJ500, see wiring illustration on following page:
http://waterheatertimer.org/ST01C-program.html#ST01C
If this is not your timer, then add a comment.
Wiring is dependent if you are replacing single pole switch or 3-way switch.
For single pole switch replacement:
Old switch has two wires.
Connect these wires to timer blue wire and timer black wire, in either order for now.
Green connects to bare ground wire.
Turn power ON.
Click timer on-off button.
If lights turn ON-and-OFF, then timer is wired correctly.
If lights do not turn ON-and-OFF, then reverse blue and black wires.
Timer red wire is capped off with wire nut
If your lights involuntarily blink after pushing ON-OFF button, then timer red wire is connected where timer blue wire should be connected.
For 3-way switch replacement, there is also a wiring diagram shown on link above.
Keep in mind that ST01C and EJ350 cannot replace a 3-way switch wire-for-wire.
Blue wire must always go to Load.
The other 3-way switch is also wired differently.
Add a comment with careful description of your wire colors and I will respond.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps while you are wiring the device for a price.
Dec 26, 2010 | Intermatic & Self-Adjusting Wall Switch...
My keyless remote for toyota highlander wont work, how can i reprogram it?
To reprogram remote:
turn ignition on
press and release programming/valet switch three times ( you will hear one chirp from system)
press and release lock button on remote ( system responds with confrimation chirp)
press and release valet switch one time ( two chirps from system)
press and release unlock button on remote (system responds with confirmation chirp)
press and release valet switch one time (three chirps from system)
press and release option button on remote (system responds with confirmation chirp)
turn igntion off
test remote
Oct 05, 2010 | APS20B Prestige Keyless Remote Alarm
Turn off button not responding .. i cant turn my phone off without taking the battery out ..HELP
um, just so u kno, the E63 doesnt hv a power off button on the top of the phone, just one of its characteristic features. maybe u'd wanna find out more abt the phone before giving advice. i'm just saying.....
Mar 23, 2010 | Nokia E63 Cell Phone
LG KS20 operating fault
Try to make hard reset but first save your contacts and files in memory.
Hard reset is like that,you switch off the phone,hold the left button of volume decrease,hold the answer button and the on.off button untill the 3 leds(lights) will flash
Jan 08, 2010 | LG KS20 Smartphone
Doesnt respond to the power button
Two things, it could be a bad power button or the battery is not providing enough power that causes the phone not to respond immediately.
Try to power cycle the phone by removing the battery for 5 minutes then put it back on. Check if the phone would respond properly.
If not, check the power switch and see if there's something blocking the switch or it might need repair.
Aug 01, 2009 | iRiver E10 Digital Media Player
Olymp. DS-330,None of the Buttons respond at all,only hold slider
If you remove the batteries and reinstall, does the display indicate Hold at some point? The hold button sometimes breakes and doesn't activate the switch. Pop off the hold button and move the internal switch manually.
Nov 21, 2008 | VXI Corporation VTR-3200 Handheld Digital...
HTC Desire Cell Phone Logo
24 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
