Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer stops mid cycle - Maytag Atlantis MAV6000 Top Load Washer
  • Maytag Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the fault repeats all the time to stop after a said period then it can be a fault on the panel board. check also the power supply to the board, check power to the processor.
Posted on Jan 15, 2013
Coldcut
  • 1554 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
The belt is slipping and needs replaced.
Posted on Jan 26, 2008
Lumpy816
  • 246 Answers
SOURCE: Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
Posted on Jun 16, 2008
mumma_1
  • 903 Answers
SOURCE: maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Posted on Oct 26, 2008
  • 27 Answers
SOURCE: Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Posted on Mar 07, 2009
  • 17 Answers
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Posted on Oct 24, 2009
Maytag atlantis mavt834aww stopped in mid cycle and now won't do anything.
Try unplugging it wait a minute and replug it in. This will sometimes reset the main board.
Sep 25, 2011 | Maytag Atlantis MAV6000 Top Load Washer
MAYTAG WASHER THAT WAS IN MID CYCLE AND STOPPED AT THE RINSE AND SPIN PART. TURNED OFF THE WASHER AND TURNED ON BUT MAKES A CLICKING NOISE. ALSO LOUD WHEN ITS IN THE SPIN CYCLE. HELP!!!
Sounds like the clutch spring is broken. You should have a UC or DC error code showing on the display. Only fix is to replace the clutch assembly.
Oct 22, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Stops in mid cycle
Hi, is the water heating up? if not it might be a faulty heating element.
Aug 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
May 09, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Stopped working in mid cycle
lid switch assemblie.its the part where if you open the washer lid all stops,its that part.you may buy it on line with you model and ser# or at a local appliance store. God bless ,tom
Jan 30, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
