Question about Microsoft Xbox 360 Console
Red lights on xbox
Hi there got probelems with my x box : had one red light to start with so i performed the x clamp replacement cleaned both the cpu & the gpu put on new heat sink compound replaced both heat sinks swiched it back on to find now i have 3 red lights left it on for around ten mins so the chip would over heat giving me two lights but i still have 3 red lights can you help in any way ? many thanks chris!!!!!
  • 51 Answers
3 Red lighs means a hardware failure. If you've opened up the console you have void the warranty so you can't get it replaced. It would have been a quick fix in a certified repair shop with one ring and your warranty would still be valid. Unfortunately, you will have to attempt to fix the console yourself or get a new one. I recommend you get it replaced though.
Posted on Jan 24, 2009
My x box keeps on freezing
The freezing happens before the red lights.
It happens because the main chips inside the Xbox 360 are losing connection - you need to stop the heat build up between these and you will be able to fix it.
You can either send it in or use a good repair guide to fix it from home.
Apr 23, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
X box game wont come on. red light flashing
if all four lights are red your av cable or hdmi is loose. if its 3 red lights this is the red ring of death (RROD) and it needs repair. microsoft has a 3year warrenty for this problem. what happens is the console gets hot and the "x" clamps holding the heat syncs to the chips bends the motherboard and causes the CPU or GPU to come loose enough to where they aren't making proper contact with the board. I've fixed several of these including 2 of my own. what you do is take it apart, remove the clamps and the heat syncs. clean the chips. apply new thernal paste and replace the problem causing clamps with screws and washers. plug in the xbox with out the fan hooked up for about 3-5 minutes until you see 2 red lights flashing which indicated the console is ovrheating, let it overheat for 2 minutes unplug it and tighten the screws. the overheating of the console softens the solder on the chips and allows you to tighten the back into place.
This is the video I watched to learn the process. Its part 1 of 9 i think">
Oct 17, 2010 | Video Game Consoles & Games
My xbox 360 have sound but no vedio, so i did what the vedios say do by changing the x clamp and put new compound on both side then after ploging it in i had no red lights like they say i would my360 start...
Overheating which is the 2 red lights mean there is a problem with the cpu,this is the one under the big heatsink.
Things to try:-
If you have not already done so the cpu needs the heatsink compound replacing.
check the spacing between the motherboard and the heatsink on the cpu, are all the washers in place.
When you screw the chassis to the casing tighten all the screws up then loosen them all off by one full turn.
I hope this helps.
Jan 13, 2010 | Microsoft Xbox 360 Console
My Xbox 360 just started turning itself off after about 4-8 mins.2 red lights come on ,on the left side while laying flat.
Correct!
You are having an overheating problem. 2 red lights indicates that the console is overheated, and to preserve itself it will shut down. You may want to try and replace the thermal compound between the cpu/gpu, cleaning them off first, To do this you need to open the xbox and remove the x-clamps.
Oct 20, 2009 | Microsoft Xbox 360 Controller
XBOX360 No Audio, No VIdeo, Solid Green Light
the G.P.U has more than likely detached from the main board.
the x clamp mod is more of a diagnostic procedures than an
actual repair function. The G.P.U will need to be re-flowed to
the main board then lightly but firmly clamp to the board
then stress tested (force it to run hot for 15 min shut off and
repeat 3 times)
that's it
Aug 23, 2009 | Microsoft Xbox 360 Console
Scratched Xbox 360 motherboard
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
May 29, 2009 | Microsoft Xbox 360 Console
X box 360 console
Most of the time when you have 2 red flashing lights one of the clamps has come loose holding down the cooler on the GPU or CPU.
Dec 30, 2008 | Microsoft Xbox 360 Console
Red ring of death error code 0102
The red ring of death is a generic error code due to the design of the xbox. Microsoft has offered an extended three year warranty to anyone who is afflicted by the red ring of death. Try calling them at 1-800-4MY-XBOX with your consoles serial number, and they will start the replacement process to repair your console.
Aug 29, 2008 | Microsoft Xbox 360 Console
Reds light's
you can't just remove the 2 x clamps, you need something to hold the heatsink down. Get yourself some m5 screws and washers and screw it down to hold the headsink, cpu and the board together.
Jul 27, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
