Question about Whirlpool RF262LXS Kitchen Range
Wiring that leads to bake element on Electric Range is not long enough to fit through the slot in the back of the oven.
The bake element on my Whirlpool Electric Range stopped working, so I ordered a new one, and when I went to replace it, I found that the wiring that comes in through the slot in the back of the oven was not long enough. They did not even pull through enough to be able to connect them to the new heating element. I took off the back panel of the oven to pull the wiring further down and further into the slot, but found that the wires are simply not long enough. What are my options here? Shouldn't the installer have known better than to connect wires that were too short for their intended purpose?!
  • 3,828 Answers
Thats why electricians carry long wires and junction boxes of all sorts in their trucks
a solution's is to use a junction connection box and add a new length of wire to the oven side
Wiring that leads to bake element on Electric Rang - images-4l3mo04yvnp2xdvhjfffy5rf-3-0.jpg
Posted on Apr 16, 2017
4 Suggested Answers
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
Techsim
  • 59 Answers
SOURCE: Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Posted on Nov 03, 2008
SOURCE: Whirpool electric oven replacing bake element
In addition to what aborcass stated, I just had to fix the same problem. Remeber to turn off the power before you do this. On my stove the element acess is behind the side panel (right side when facing the stove). You remove two screws on the back and one underneath at the bottom, (you need to pull out the drawer). Once screws are out, slide the side panel forward gently about an inch and it should just drop off.
You should see the wires for the element level with the bottom of the stove. The wires will guide you to the element. And you should see that the element is screwed in with two screws to the stove. This is the tricky bit, to remove the element follow the metal piece holding the element to the right until you see a third screw. Remove this screw and the whole thing will come out. Take off the wires, replace the element on the metal strip, slide the element and metal strip back into the stove (take care to ensure the left side of the metal strip slides into the proper position under the metal clasp. Re-attach the screw, plug the wires onto the element and turn the power back on. You should have heat.
Good luck.
Posted on Apr 05, 2009
How do you remove the moulded Hidden Bake Element from the inside whirlpool ceramic range accubake system
first, remove power from the unit before doing ANYTHING! second, remove the back cover of the machine, this will expose another smaller panel with 4-6 screws in it running along the bottom edge across the back. after removing the screws you will have to gently BEND the panel down until you can see the wiring leading to the hidden bake element. cut the insulation covering the back of the element... be sure new element is placed in the exact location of the old one to avoid shorting the bake terminals to the metal cover, then reverse the removal process...
Apr 26, 2016 | Whirlpool 30" Self-Cleaning Freestanding...
Tip
Replacing the Bake or Broil Element in an ELECTRIC Oven
This advice is on how to replace a bad element on kitchen ranges that utilize ELECTRIC heating elements for baking and broiling.
1. UNPLUG the range and remove the rear panel. Dangerous voltages are still present with the range turned off. The rear panel is in close proximity to the input power terminal block & shock hazard and/or equipment hazard can exist. Remove the series of screws around the perimeter of the panel.
2. Locate and disconnect the terminal lead wires from the element. Color coding may differ between manufacturers, so make sure you mark or label the wires as you remove them. If replacing both elements, do so one at a time to avoid confusion.
3. Open the oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot remove the oven door, use care not to lean on the door or put too much weight on it. This can cause damage to the door hinges or cause the hinge springs to come loose.
4. Remove the oven racks, and remove the oven pan (if required – some elements are fully exposed, some have pan covers). There are usually two screws either in the back or front of the oven holding the pan in place.
5. The element will be mounted directly to the back of the oven wall, and/or to the bottom/top of the oven wall. Remove the mounting screws and remove old element from oven.
6. Install new element by carefully feeding the terminal leads through the oven wall first. Reinsert all mounting screws.
7. From the back of the range, reconnect the terminal wires.
8. Plug range in, turn oven/boiler on, and perform a visual test of the heating element to ensure it is working properly. Turn oven/broiler off and allow sufficient time to cool. If the oven has only been on for a minute or so, the cool down period will be brief. NOTE: Stand clear of any exposed wiring with rear panel removed.
9. UNPLUG range once again and re-install rear panel ensuring the terminal wires are NOT touching the panel.
10. Reinstall the oven pan and racks. Reinstall door if necessary.
NOTES: Prices vary between models and manufacturers, but most elements are in the $20-$40 range. There is a difference between the BROIL and BAKE elements in that they are usually different wattage ratings and are shaped differently. They should not be considered interchangeable. Good luck & I hope this information is helpful.
on Dec 04, 2009 | Kitchen Ranges
Tip
on Mar 26, 2008 | KitchenAid KESC307 Electric Kitchen Range
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Kenmore electric range mod.750.9210,9220,9230,9240 Oven does not come on
Check fuses first. If OK, Unplug from wall, unscrew the bracket that attaches the lower bake element to the wall of the stove..(usually held to wall by a few small screws). Clip VOM test meter leads to the two terminals. Set meter to at least 250V AC. Make sure test leads and screws do not touch any metal anywhere. Best is to put a piece of plastic or cardboard under the test leads to isolate the leads from the bottom of the oven. Once connected and properly isolated, plug stove in, turn stove on to bake 350 degrees and look at the voltage reading. If 250V is there element is bad. If no voltage switch or wiring between switch and element is bad.
Aug 08, 2014 | Kitchen Ranges
Bottom oven bottom element doesn't heat
Phil. If you do not have voltage at the element, then the Electronic Oven Control ( EOC ) has failed. Part number # 5701M403-60
In order to check for the correct voltage at the element you will need to remove power and pull the range out of its installed location and remove the back panel of the range to gain access to the wiring and element. CAUTION ! I cannot stress this enough ! There are dangerous voltages in this area!! After the panel has been removed, return power to the range,set the lower oven to bake, and check the voltage at the element. You should find 220-240 volts between the element terminals with them connected to the element. If you do not have the proper voltage then you will need to replaced the EOC.
Apr 18, 2014 | Maytag MER6772 Gemini Electric Kitchen...
Baking element replaced but still won't heat
you may have triped half your 220v breaker. (you should have shut it off when reparieng wire or it would have been live and zaped you) Or something in line with the wire that shorted blew out like a fuse in the range.
Nov 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Need to replace baking unit on Hotpoint range
Difficult is a relative question, I don't think it's very difficult though.
**First-Unplug the unit from the wall, or shut off any power to the unit.**
All you should need is a robertson screwdriver, perhaps a philips and slotted depending on the existing screw heads (square,star and flat) Remove the two screws at the back of the element bracket. Once they are removed, carefully pull the element a couple of inches from the oven cavity, there will be 2 wires connected to it. Hopefully the wires will be long enough to allow you to do this from the front, if not you'll need to remove the back panel of the range. If you have wires long enough you can proceed to remove them and install the new element in the reverse procedure.
You may also require a pair of pliers as well to remove/install the screws on the bake element, hold the connector with the pliers, and turn the screw with the driver so as not to twist the connector in a circle and hence ruining your new element.
*Note; inspect the connections of the wires to the element, if they look burnt, cracked, or just barely hanging on, replace them. you'll need to purchase (if you haven't already) a wire stripper/crimper and some new fittings. Make sure the new fittings/connectors are of the "hi-temp" (usually chrome/nickle plated) variety. Regular metal connector's will fatigue in a short time, relative again to how often the bake is used.
hope that helps, let me know if you need any further assistance.
Good Luck :)
Oct 23, 2009 | Hotpoint Ovens
Replacing baking element for GE Truetemp
I just had the same problem. Just remove the rear panel of the range and unplug the two leads. Now go to the two screws inside the oven and remove them. The heating element will now come out and you can insert the new element the same way. Replace the two screws inside the oven and then attatch the two leads in the rear. Replace the rear panel and you are set to go.
Jan 25, 2009 | GE Spectra JBP78 Electric Kitchen Range
Electric range not heating
Remove back cover of control and check bake leads. Or turn power off. Remove element (bake) pull forward slowly to expose the connections to element, remove from element, make sure they do not retract back into cavity. Make sure they do not touch anything and turn on power set control to bake then check voltage on leads. 240 volt is what you need. If no voltage then replace control. If voltage is present replace element.
Jul 12, 2008 | GE JBP65 Electric Kitchen Range
Whirlpool RF262LXS Kitchen Range Logo
113 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
