Question about Kohler Home
Bad cylinder for the main showerhead on a Kohler MasterShower Tower K-74
New cylinder cost around $500.00 retail. what are my options fixing vs replacement with a new brass showertower that fits the same space as Kohler MasterShower Tower K-74
4 Suggested Answers
jonbrown725
  • 73 Answers
SOURCE: Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Posted on Jan 17, 2009
  • 10865 Answers
SOURCE: Kohler KT12007 Showerhead
The device which directs the water up or down is called the diverter. Your diverter is not fully up or fully down. Rather forcefully push and pull the diverter a few times and your problem may be solved. good luck.
Posted on Jan 25, 2009
  • 653 Answers
SOURCE: Water coming from showerhead and bath spout at same time
Have whoever installed the shower set come back and fix the diverter. It should be a relatively simple adjustment.
Posted on Mar 15, 2009
Kohler Loure Hand Held Showerhead
if it looks like you can not you probably need to get a cordless drill and a drill bit a make a hole through it...be careful and clean out shavings ...this works great...i am a licensed plumber and have done this when needed and this will give you a much better flow...good luck..
Apr 23, 2014 | Kohler K-14681-CP Loure Showerhead, Arm...
How to replace soap dish on kohler mastershower slidebar. can't seem to take it apart.
Dear Sirs,
You have to deassamble the part then you can take of the shop dish
Oct 10, 2013 | KOHLER MasterShower Three-Way Brushed...
The "turning" part of the head has almost become
yes you just have to be careful to align back up and tighten all parts...
Feb 15, 2011 | Kohler K-8506-CP Polished Chrome...
Shower is dripping. how do you make sure you find the exact diverter replacement? Does it matter?
If you're talking about the diverter just like the one in that picture, then no. You do not need to get a Kohler diverter, as Kohler utilizes the 1/2 NPT(national pipe threading) threads that most showers are compatible to. You can pick one up from your local hardware stores. Make sure you teflon tape all the male threads before you install them.
Nov 25, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Feb 28, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Mar 15, 2009 | Kohler Home
Shower arm is loose
The best way is to cut a hole in the wall and fix it right. That will entail replacing the surface material, probably sheetrock. You could try some silicone sealant around the shower arm behind the eschusion. It will still move, but not much.
Mar 04, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Jan 24, 2009 | Kohler K-T12007-4s-BV Brushed Bronze...
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Home Logo
43 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
