Question about HP Officejet 6700 Premium E-All-In-One Printer
Unlock hp 6700 printer fax
Cant unlock fax settings
My HP 6700 says "unable to scan copy or fax.Can you help ?
There can be several reasons, so to help you troubleshoot the issue about unable to scan copy or fax, it is recommended to download and install 'Hp Print and Scan Doctor' from the link below:
http://support.hp.com/us-en/document/c03286146
Also, you can find more troubleshooting steps mentioned on the link.
GuruAid.com
Apr 08, 2016 | HP Office Equipment & Supplies
How do i clean the printhead of hp officejet 6700 premium
Using the HP Printer Assistant (comes with the driver package), choose the Estimate Ink Levels Option. At the top of this page, select the Device Services Tab. There is a Clean Printheads Option there. Be advised this goes thru some serious ink. I have a 6700 myself and am so disgusted with the ink usage rate that I have purchased a different printer for actual printing. I only the the 6700 for scanning and faxing.
Oct 22, 2015 | HP Office Equipment & Supplies
All settings on printer are shown as "Locked". I didn't lock them and can't unlock them.
Try accessing the Embedded Web Server in the printer.
e.g. HP Photosmart C4380 All in One Printer Series and C4550 C4580 and C4585...
(the EWS can be accessed in the 6700 series All-In-One printers using the same process as in those printers.)
Jun 16, 2015 | HP Officejet 6700 Premium E-All-In-One...
AUTO ANSWER on fax receive does not answer fax.
You need to talk to HP tech support... to do a proper reset you need to access menus that are meant for tech support and developers only. If you "brick" your OJ using those menus on your own (including instructions from anyone here), it's considered customer damage and voids the warranty. If you post your request at the link below, you should get a PM from an official HP tech support person telling you how to do the reset.
Officejet 6700 premium won pick up faxes
Mar 07, 2015 | HP Officejet 6700 Premium E-All-In-One...
When I RECEIVE a fax, the screen says INCOMMING FAX from the sender, AND it shows AUTO ANSWER: ON. There is a button for ACCEPT, which if I hit it, will answer the call and print the fax. The problem is...
8500 hp printer -- cant get red of message -fax log full
clear the fax log...
go to setup menu basic fax setup... scroll to fax log... clear fax log....
in some printer you can find the fax log in the fax settings or advance fax setup..
Feb 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I cant seem to set up my fax for incoming
Uninstall printer prog restart, then reinstall printer programme. This time sit with computer while prog installs, it will ask you question once whole prog installs, you most likely missed the information to install for the fax part?
Nov 01, 2009 | HP LaserJet M1522n MultiFunction Printer
HP Officejet 6700 Premium E-All-In-One Printer Logo
128 people viewed this question
Seeker5211
Seeker5211
