Question about Dell Dimension 2400 PC Desktop
Hold each keystroke down for several seconds to get letter
How can I fix I have to when hold each keystroke down for several seconds to get letter
    Scholar:
  • 57 Answers
Does the mouse work well? When you open a file, does that take a long time, too? Is it happening all the time?
I'm not sure it will help solve your problem, but it's possible you are experiencing a "typematic" feature. To save typing, there is an execellent explanation at:
http://www.pcguide.com/ref/kb/swTypematic-c.html
Posted on Jan 23, 2009
A55A asus laptop will not boot nor do f keys work,would need cheat keys possibly to get in there.
Windows 7 and 8 require different keystrokes to boot into Safe Mode, which is your best bet to get help from Windows to diagnose and fix operating system booting errors. Holding down or tapping just the F8 key, the time-honoured method to get into Safe Mode, does not work with Windows 8. Here's a link that explains several ways to get into Safe Mode in Windows 8.
Knowledge Base
Dec 31, 2017 | ASUS Computers & Internet
K55A Asus will not boot and f keys dont work?
Knowledge Base
My Dell laptop keyboard settings have apparently been changed-I have to hold down the Fn key to get the letters on the keyboard instead of the Fn items indicated on the keyboard. How do I fix it?
Maybe this is the result of inadvertently turning on "Sticky keys" (see the Accessibility Control Panel Help file). Try holding the Fn key down for several seconds with no other key pressed to see if that turns off the Fn lock-on. After that you can disable the Sticky Keys function in Accessibility.
Feb 09, 2011 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
I have an hp mini laptop..whenever i press letters u,i,p,o,j,k,l,m it shows numbers 4,5,6,1,2,0. maybe i had typed something which made this like this..how do i do it.
The problem is that you have to turn off the number lock hold FN key and press the scroll button wherever its on your keyboard usually its after the f12 key,, that should fix your problem...
Jun 08, 2010 | HP 2133-1 Mini-Note PC
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
Keying numbers instead of letters whun num lock on
Check 2nd Function keys. The problem you describe is normally a Fn +numlock keystroke on most systems
Dec 27, 2009 | Compaq Presario 700 470024-192 Notebook
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
Q key keps printing
Understand and use (or make sure they’re turned off) keyboard Accessibility Options. There are several types of help for those with typing difficulties, namely:
StickyKeys is an accessibility feature designed for people who have difficulty holding down two or more keys at a time. When a shortcut requires a key combination such as CTRL+P, StickyKeys will enable you to press one key at a time instead of pressing them simultaneously.
FilterKeys: You can set Windows to ignore keystrokes that occur in rapid succession, or keystrokes that are held down for several seconds unintentionally.
Bounce Keys: If you bounce your fingers on keys inadvertently, Bounce Keys will ignore repeated keystrokes until some time has passed. You choose the time period.
Repeat Keys and Slow Keys: The computer will ignore brief keystrokes according to the time limits you set. To access these Options and turn them off or on, go to your Control Panel– click Start >Settings >Control Panel >Accessibility Options.
By default it opens to the keyboard tab. If you are experiencing a sudden onset of bizarre typing behavior, your first step is to visit here and ensure that there are no checks in the three checkboxes, which indicates these Options are in use.
I mentioned that shortcuts ‘activate’ these features — such as Tab+Enter, and a couple of Alt+a letter– and so you may have turned them on unintentionally.
If you do have some difficulty with your typing, such as happens when a Mr. Arthur Itis comes to visit, or/and if you have tremors, here is where you can enable these aids and tweak their settings to get the most benefit from them. Click on the “Settings” button to see the choices. Below is the FilterKeys Settings dialogue.
In the case mentioned, my client had first held down the Shift key long enough to activate FilterKeys (because a finger “rests” there). The lady was an extremely fast typist, and this setting ignored her strokes as being too short. Since she has no use for this tool, I recommended that she uncheck the top checkbox and disable the activating shortcut.
This screenshot shows the settings for StickyKeys, and unless you have trouble holding down more than one key at the same time — such as Ctrl+Alt+Del to activate Task Manager — I suggest you uncheck the top checkbox here as well.
Aug 19, 2009 | Lenovo 3000 C100 Notebook
Dell keystroke delay
This type of thing usually happens because the computer is doing other things such as accessing the harddrive or or any other number of things. You can test this by booting into safe mode and see how well your keyboard responds. You will probably find it works fine there. You will need to isolate what other activity is slowing your computer down in the normal mode.
If this helps can you rate this as fixya.
Thanks
Mar 09, 2009 | Dell 0Y3740 Keyboard
IBM T40 Keyboard Question
Numlock is the keystroke to fix your problem.
Oct 13, 2007 | IBM ThinkPad T40 2373 Notebook
Dell Dimension 2400 PC Desktop Logo
24 people viewed this question
Alun Cox
