Question about Craftsman 3 gal. Air Compressor, 1 hp, Tank
I have a craftsman 921.153101 air compresser .It builds about 60 lbs and contines to run .
It holds pressure in the tank overnight . and no back pessure out thr intake. It has a lot of crankcase pressure I think it is blow by .Can the rings be bad without looking bad ? The cylinder looks and feels good.
  • 80 Answers
Might be the valve plate is worn or has a broken reed.
Posted on Jan 16, 2013
SOURCE: lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Posted on Nov 25, 2008
  • 1388 Answers
SOURCE: Will not build up pressure
If this compressor is dry type with no oil needed, then it may have a worn cylinder and/or piston ring. With flashlight in hand, look under cylinder with piston in upper most position. If you see scratches most likely it needs cylinder / piston kit. Not to worry, not too expensive. If you compressor has a crankcase with oil, then you may have problems with valves in the head. Cracked or dirt under headvalves will prevent pressure from building. Finally there may be one or several leaks in the tubing, check leaks with soapy water. enjoy
Posted on Nov 29, 2008
  • 89 Answers
SOURCE: tank will not build pressure beyond 25 lbs. Just runs
IS YOUR AIR FILTER CLOGGED. SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT - NOT TURNED OR FLIPPED OVER. SEE IF YOUR FINGER WILL GET SUCKED UP TO THE INTAKE HOLE.
Posted on Apr 12, 2009
protek480
  • 1714 Answers
SOURCE: WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
Posted on Sep 11, 2009
wiringlunati
  • 576 Answers
SOURCE: Air pressure does not go over 25 psi I have taken
Does it shut off at 25 psi or just keep running and never build more pressure than that? Also, did this come on gradually or suddenly? Also, was it being used regularly when it happened or had it been sitting for a while?
Posted on Mar 07, 2010
Charge air pro model ir330e20 builds pressure to only 60 psi and will not stop running
Cbillgreene:
Your compressor is leaking air somewhere between the compressor head and the tank. With the compressor running, feel carefully around the ends of the tube that leads from the compressor head to the air tank. You will probably feel some air leaking around one end or the other. If so... remove the tube and find out which packing has failed.
Mar 09, 2013 | Craftsman Air Tools & Compressors
I have a flotec 1 hp pump. Wife washed 3 loads of clothes in a row and noticed we run out of water a while later. I shut pump off and noticed pressure tank low on air. I put 18 lb. air in tank and...
If in the past your system can build-up pressure up to 40 psi even if the supply valve is open and water is being used in your house, then your pump impeller maybe already worn out that's why its pumping capacity was reduced.
Nov 12, 2012 | Flotec Corrosion Resistant Shallow Well...
Compressor runs and sounds ok, but it only manages to show 20 lbs. It will not build air pressure and continues to run.
check air tank drain valve located on bottom of tank, if it is not leaking try adjusting air pres regulator (large black knob close to air hose connection.) the knob when turned in will increase the tank air pressure, if knob wont turn check that lock ring on bottom of knob to make sure it is disengaged. also check for air leaks in all lines and connections
Apr 16, 2012 | Craftsman 1 hp Air Compressor, 4 gal. -...
Air pressure only builds up to 45 lbs. compressor continues to run. I drained all the air and it still only builds up to 45 lbs.
The check valve is not holding the pressure back off the head,therefore allowing the pressure to build up fully.
Jan 04, 2011 | Air Tools & Compressors
Craftsman pro mod# 919167770 , oilless air
Check to be sure your drain valve under the tank is turned completely off first
Mar 12, 2010 | Air Tools & Compressors
Sep 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Compressor builds to 60lbs and no higher, does not shut off
the valve plate or the piston damage
wear and tear
take it apart and check
when installing use gasket maker to seal it back
Aug 03, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Tank will not build pressure beyond 25 lbs. Just runs
Apr 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Craftsman 3 gal. Air Compressor, 1 hp, Tank Logo
226 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
