Question about D-Link Dlink Xtreme N Gigabit Router Dir655 Wireless Router 4port Switch
Charter cable modem and dlinkdir 655 periodically lose connection
Some random time almost every day, the modem and dlink indicators show they are connected, however, internet connection is lost.
  • Phil Mengel Jan 16, 2013
    After I disconnect & reconnect and router reboots, internet connection is restored. Annoying problem. Any ideas to fix?
    Sergeant:
  • 378 Answers
Router might be bogged down at times causing it to fall off network. try pulling one device from router and if it continues try another. you could also try another power source for the router
Posted on Jan 29, 2013
Arris TM902 modem (CHARTER) causes random "waiting for 24.217.29.129" hangs. 24.217.29.129 is for Charter in Denver Col. How do I fix this ?????
This is (for me, anyway) caused by a routing problem within Charter's network. They inject a redirect to a page to try to force you to agree to terms and conditions. That page is on 24.217.29.129. For me, that IP is unreachable - a traceroute shows a routing issue inside Charter's network - a packet bound for that address ends up bouncing between 2 of their routers and eventually the TTL expires. Their useless troubleshooting chatbot will just want you to reset your cable modem, which will do nothing but waste your time - the problem is inside Charter's network.
Dec 14, 2016 | Arris Computers & Internet
Keeps losing connection? charter says no problem with them, motorola is no help.....
Check / replace the power supply. Also check your cable. If you have access to where the cable comes into your house, try connecting a brand new cable at the box and connecting to the modem. If that solves it, then you need to have the house cabling checked / replaced. If not, then there is most likely a fault with the modem. Do you have any friends with cable Internet you could check out the modem at their house? Maybe swap cable modems with them for a short time to see if the fault travels with the modem. If both work at your friends house and neither work at your house it is is a problem with charter and they need to come out and verify the signal strength if they have not done so. If the problem is intermittent, is it a particular time of day? Cable services theft is a big problem and somebody may be tapping in to the line causing signal loss.
If none of the above helps, post much more information and what you have done to solve the problem.
Best of luck, Jim
Mar 05, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
I lost my setup cd for my dlink dir-655 wireless router. how can i find the software and drivers?
You can set up your router manually, without the
CD.
Make sure that your computer is able to go online
directly through the modem.
If your computer is able to go online through the
modem, that means the modem is working fine.
You will need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for more information about the routers
and network
Jan 22, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Hooking D-Link 655 to a Ambit Cable Modum with Charter Cable, Cannot Get it to Configure. When modum is directly plugged to modum internet is fine, but I cannot get throught he setup stage when hooking the...
I have dlink 2100ap wireless router any body had access my wireless network but i want to ristrect network just like network passkey how can i give my dlink 2100ap wireless router pass key please give me reply
Sep 24, 2009 | D-Link Computers & Internet
I am unable to connect to the internet with my dlink
Just connect my dlink 615 to a new dell computer on the vista page for the Network and internet the broadband connection is disconnected. What can I do to connect it? When I switch the dlink network back to the old computer everything works fine.
Aug 03, 2009 | D-Link Xtreme N DIR-655 Wireless Router
There is an Excellent signal but it's not connecting
That´s because of the ip assignment you have to set the ip of the router in the same net work ip scale of you modem that connects you to your isp example if ip modem is 192.168.0.10 then the ip you must set on the wan port mustbe 192.168.0.100, also check that you are connecting the out of the modem to the wanport on the wireless router.
Hope it helps
Jun 25, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Can't connect to my K-jam to my new DLink DIR-655 wifi router
Can't connect to my K-jam to my new DLink DIR-655...
Mar 11, 2009 | i-mate K-JAM Cellular Phone
D-Link Dlink Xtreme N Gigabit Router Dir655 Wireless Router 4port Switch Logo
119 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
