Question about Miele 24 in. G643Vi Plus Built-In Dishwasher
I have a miele dishwasher model G 868 U AND WOULD LIKE TO FIND A STAINLESS STEEL DOOR TO REPLACE THE WHITE ONE CAN ANYONE HELP?
  • 9 Answers
SOURCE: miele dishwasher film and crust on the inside-
Hard water has this "crust" which are minerals floating around that ionically attach to everything. Some machines from Miele have a water softener inside the machine. Special dishwasher softener Salt is added that cleans minerals off Xeolite beads. When cleaned they attract mineral ions. If you don't use the salt then the beads fill up on minerals until they can't hold any more minerals. The salt is used in the regeneration cycle. It washes the mineral ions off the xeloite replacing them with salt ions. As new water enters the machine mineral ions slowly knock off the salt ions and attach themselves to the beads again. This whole process keeps the crust off the dishes and the walls of the machine.
Use a dishwasher cleaner that removes scale. And if you don't have a salt light on your Miele you can instead purchase soap tablets that contain water softener built in. Miele dishwasher tablets have it. You can order them online or call Miele.
Posted on Apr 20, 2008
  • 2920 Answers
SOURCE: looking for a steam deflector.
go to a used appliance store they can help you with what you need..they may have one on hand they can sell you
Posted on Jan 29, 2009
dragonsthatk
  • 547 Answers
SOURCE: Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Posted on Feb 25, 2009
SOURCE: Obtaining Miele Dishwasher parts
Miele's US website lists a toll free call in # for parts under the customer service heading. I found them to be helpful and informed. See below:
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
Posted on Dec 24, 2009
SOURCE: Miele G858 Icognito replace bottom door seal...how to remove door
Kelly --
Since you wrote your question 13 months ago, I'm guessing the problem is solved. Still, for others experiencing the same issue, here's my answer.
We also experienced leaking on our Miele 858 Incognito dishwasher and were able to replace the bottom door seal (today) without removing the door.
First, call the Miele Parts Dept @ 800-999-1360 to place an order for the door seal, which is part #3920725.
Remove the defective seal by loosening the four screws at the bottom of the door. Pull the black rubber seal out and discard. Install the new part in the same spot (underneath the green flange). Tighten the screws and you'll be in business.
Posted on May 08, 2010
I need to replace the thin white door panel on a MIELE G832SC touchtronic turbothermic dishwasher
you want the replacement to be white as well? Check out ApplianceArt.com, they have over 200 different panel options including stainless steel, black, and white.
Nov 11, 2010 | Miele 24 in. G643Vi Plus Built-In...
I want to replace the white door panel with stainless steel
Have you checked with www.applianceart.com? They have faux stainless and real stainless options. PLus a ton of other choices there.
Feb 21, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
I have a frigidaire dishwasher FDB2415LFSO white and would like a stainless steel finish. Are there door panels available for this model?
yes / when changing to ss from white . most people wasnt the black control panel . as it looks best . the cost of the panel and stainless . is costley . and inless dw is newer model . most would look at the cost of a new one .. hple this helps mm
Dec 08, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Is there a replacement door for a Kitchenaid kudi01tjwh0 dishwasher made of stainless steel? Maybe another model with the same size/layout of the door?
Applianceart.com has stainless steel options for door panels as well as a faux stainless steel that was on HGTV. I'm not sure if the panels they have would fit your model, but their rolls of stainless would definitely help.
Nov 24, 2009 | KitchenAid 24 in. KUDI01TJ - Multiple...
I don't have a problem, but would justy like to
Hello. Not all dishwashers have multiple panels which you can interchange. However, you always have two other options. One is to paint the white cover with stainless steel spray paint.
You can do this yourself with spray cans available from home depot, or you can remove the door and take it to an autobody shop to have it professionally done.
you can also have a piece of stainless sheet metal cut to size at a metal fabricating shop and use a construction adhesive to attach it to the front of your dishwasher, using stainless outside corner trim to finish the job.
Oct 25, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
White to stainless
Black, white and bisque seem to be the only colors available for the double convection oven. Might be possible to find the cooktop, but it's hard to know for sure without the model number.
In my experience, it's often not economical to switch to stainless steel as stainless steel panels can be extremely expensive (I've seen a freezer door on a side by side fridge sell for over $850... Just the freezer door!)
Mar 05, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
If i have a problem with my mdb7601aww dishwasher door can i replace it with a stainless steel door instead of the white door
When I searched the parts list for your dishwasher, I only found the door panel available in white but call the manufacturer and ask them because I believe you may be able to change to stainless.
Feb 25, 2009 | Maytag 24 in. MDB7601AWS Stainless Steel...
Miele 24 in. G643Vi Plus Built-In Dishwasher Logo
75 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
