Question about Tools & Hardware - Others
Evcon coleman furnace - Tools & Hardware - Others
I have a Evcon mod.# DGAH077BBSB with 4 light flash code
Posted on Mar 06, 2009
4 Suggested Answers
  • 221 Answers
SOURCE: i have a coleman evcon furnace and it wont work it
One flash mean ignition failure. The sequence is: T-Stats calls for heat, inducer motor comes on, igniter glows orange (look through glass), then gas comes on and burner lights, approximately 1 minute later the indoor blower comes on. If you don't see the glow, most likely the igniter is bad. If you see the glow but no flame, it's a gas problem, supply or defective valve.
Posted on Dec 31, 2009
  • 221 Answers
SOURCE: COLEMAN EVCON FURNACE .. The draft fan keeps
Make sure the Thermostat fan switch is in the "auto" position.
  • 221 Answers
SOURCE: need schematics for coleman evcon presidential
The schematic is inside the panel where the wiring is.
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Our coleman evcon furnace has started clicking over & over again before it starts up, we replaced the thermostat & the same thing happens.We are afraid that this is hard on the furnace & have resorted to...
Suspect that the igniter is causing the clicking (or could be a relay). Suggest having the furnace serviced. There is also a major recall for some models of the Coleman Evcon furnaces.
Oct 29, 2013 | Heating & Cooling
Coleman EVCON GAS FURNACE ugab075bua
Would need to have a serial number to determine.
Oct 13, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace is noisy loud
To many possible answers to this. A description of the noise will help to diagnose the problem.
Jan 28, 2013 | Coleman 7990-319p Evcon Gas Furnace...
How do you replace a pressure switch on a coleman evcon furnace
The pressure switch is mounted with 1/4" or 5/16" self tapping screws and has 2 wires and a rubber tube that attaches to the induced drafts assembly.
Jan 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Tools & Hardware - Others Logo
819 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
