Question about Homedics Envirascape Rustic Illumination Lantern Fountain - Black Wfl - Canrus
Homedics Envirascape water lantern fountain
Water won't pump
  • Light Aug 20, 2013
    Remove the pump from the water and make sure it's dry. Take apart the pump- the pieces should easily click apart. Take out the impeller and make sure that it is spinning correctly when plugged in. There is a thin metal part that sticks out- make sure this is straight and not curved because if it is not aligned straight, then the impeller can't spin properly.
  • 54 Answers
Impellor stuck. not sure if you can get to it though
Posted on Jan 17, 2013
My Little Giant OPWG-71 after six months of trouble free use has stopped pumping my pond. It comes on, with no obstructions allows water to be pushed through it but won't pump. And yes even when
Hi don-eyre300.
Double check your suction side of the pump for obstructions if not then it is time to replace your pump...sounds like the impeller and housing is worn beyond repair.
Bud
Apr 20, 2013 | Garden
Waterfall pump hums but won't pump
this sure sounds if the impeller is blocked and not being able to turn ,Dont let it run this way , can dammage motor of pump , remove intake cover (unplugged) and wash out with garden hose real well , see if impeller (black plastic blade) can turn with your finger (unplugged) , should move easy ! this might be an indacation of need for a filter on pump inlet !!!
Oct 14, 2012 | Little Giant Submersible Fountain Pump
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
Ornamental fountain won't circulate water, pump perfect, please help
It is presumably a submerged pump. Cleaning the pond could have accidentally blocked the pump inlet or damaged or dislodged the supply pipe.
Time to wade in and take a look...
Nov 05, 2017 | Garden
Pump hums but won't run
awwhhh it sounds as if you stored your pump dry all winter long ill bet, well ya just cant do that after it pumps salt water all summer , salt has crusted up inside pump and valves , try a hot water dose (not on motor) that might get it going again (repeat several times)
otherwise your gonna need to take it all apart clean in hot water and grease all up with foodgrade waterproof grease (see kitchen faucet parts section of hardware store)
on a salt water pool you have to store your filter and pump filled/capped with RV antifreeze (foodgrade) any good rv store sells it
salt wont crust up inside then
Mar 23, 2012 | Intex Salt Water Saltwater System Chlorine...
How high does this pump example high high can fountain top be if pump is at bottom?
From the photo on the box, it looks like it will through a nice stream 4 to 6' high.
No details available though. Make sure the outlet of the pump is right at the water surface. You will need some rocks, bricks or a hidden floating platform to make it the right level.
If it is below water level, the fountain will be much smaller (may lose half of height for every inch below surface. 1" = 3 feet stream, 2" = 18 inch stream, ...
May 06, 2011 | Pontec Submersible Fountain Pump Sp 70g
How much water do you put in it.
I need an instruction manual. I got this for my birthday but when I wanted to put it together there were no instructions to be found. You can send it to my email apowers956@aol.com thank you.
Feb 26, 2011 | Homedics EnviraScape Mariposa Illuminated...
I need new air pump for Homedics Aquascape twist lamp. Pum is Model:P-12-3
I have an older & slightly different 4 sided tapered Homedics aquarium, but it has the same pump. I used a meter to determine that the proper voltage was coming out of the transformer, measured at the plug. I took the base apart & bypassed the female connector switch the transformer plug, plugs into. Everything worked fine, meaning the fail was in the female connector, as the wires were solidly soldered on. With a magnifying glass, I could see that a rectangular "C" type copper flange, had the side that touches the side of the plug when inserted, had broken off, therefore making no connection. Using an insulated screw driver, I temporarily completed the circuit & confirmed the problem. Cut out the old female connector & take that & with the transformer (& its plug) to an electronic components store & find a suitable replacement. You will need additional heat shrink tubing & to solder the connections.
If your pump is truly not working even if it is getting power, I don't know the answer the full answer to that. A privately owned aquarium store may test the pump for you, & offer to feel or replace the diaphragm & check valves if the motor works. I see the screws are painted with locktite after re-assembly so the parts don't vibrate loose. Good Luck.
Sep 11, 2009 | Homedics EnviraScape Mariposa Illuminated...
Parts for Garden Treasures 2 tier fountain
You can find replacement parts on amazon. click here Amazon com tier fountain parts and search for your part. Hope this was helpful. cheers
Apr 05, 2009 | Garden
Homedics Envirascape Rustic Illumination Lantern Fountain - Black Wfl - Canrus Logo
238 people viewed this question
Top Homedics Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Homedics Garden Expert? Answer questions, earn points and help others
