Question about Vtech Counting Fun Elephant
Vtech counting elephant motor
The balls stopped popping
Ball filter is popping up, stopping ball rotating and ball area is getting hot
I'm sorry to hear you're having difficulties with your DC25 Animal. If the filter inside the Ball will not stay in place during use, please make sure that when you refit it, it locks into place with an audible 'click'.
I can confirm it's normal for your Dyson to become warm during use, but if you're concerned that it seems excessively hot, I'd encourage you to get in touch with us directly so we can help. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 16, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
I have a 2005 KIA Sedona, and the front wipers stopped. The fuse isn't blown and the wiper motor still works. Any idea?
I have 2002 Sedona, under the cowl the wiper linkage has a ball & socket that attaches the wiper linkage to the motor. Once in heavy snow this connection popped,I just snapped it back together and had no problem since.
Mar 14, 2011 | 2005 Kia Sedona
I need to take apart the elephant of a Fisher Price elephant train (the one with the red bird on its back) to see what has gone wrong with the motor. I have removed all the screws but need to take off the...
I suggest you to go to a mall where this item was bought, or call their hotline and asked where you can go to the nearest FISHER PRICE place for repair.
Mar 09, 2011 | Fisher Price Toys
R&R ball joints??
MOST OF THEM HAVE A ZERC FITTING TO GREASE THEM! IF YOU WANT TO REPLACE THEM: YOU WILL NEED A BALL JOINT REMOVAL TOOL ( FROM ANY PARTS STORE)! THEN YOU USE PAINT, OR CHALK, AND MARK THE PART WHERE THE JOINT IS SCREWED ON TO THE SHAFT! THIS WILL HELP YOU COUNT THE NUMBER OF THREADS INSIDE THE BALL JOINT! THEN LOOSEN THE NUT ON THE BALL JOINT ENOUGH SO YOU CAN PLACE THE BALL JOINT TOOL BETWEEN THE JOINT AND THE MOUNT IT GOES THRU! USE A HAMMER TO KNOCK IT LOOSE! ONCE IT IS LOOSE, REMOVE THE NUT, AND WASHER, AND PULL THE BOLT SIDE OF THE JOINT OUT OF THE MOUNT! NOW THE FUN! AS YOU REMOVE THE BALL JOINT FROM THE SHAFT, YOU'LL HAVE TO LOOSEN THE NUT HOLDING THE BALL JOINT! THEN REMOVE THE JOINT FROM THE SHAFT! WHERE THE PAINT STOPS IS WHERE YOU START COUNTING THE THREADS THAT WERE INSIDE THE BALL JOINT! PLACE THE NEW JOINT ON THE SHAFT, AND SCREW IT BACK TO THAT POINT! TIGHTEN THE NUT, PUT THE BOLT SIDE BACK INTO THE MOUNT, AND PLACE THE WASHER, AND NUT BACK ON IT! THEN TIGHTEN IT DOWN, AND YOUR DONE!
Mar 05, 2011 | 2004 Ford Explorer Sport Trac
Windshield wipers stopped working heavy snow stopped them now i think the cover directly below the wipers has to have an arm under it that has a clip or something that has popped off how do i remove the...
Can you hear the wiper motor running when you switch them on? If so then the plastic ball and socket link arm has popped off, You might get away with popping it back on but its unlikely and you will need a new link arm. Other than that if you cant hear the motor running (you need the ignition on) I would check for a blown fuse before going deeper into any other possibilities.
Feb 02, 2011 | 2005 Honda CRF 100 F
An old man has 17 elephants, when he was going to ...
9, 6, 1.
Answer found in less than 10 seconds.
May 20, 2010 | Computers & Internet
An elephant sat on my phone and it will not stop vibrating please help me
Austinst,
Sorry to hear about your phone.
If you want to stop the phone from vibrating, you will need to remove the battery.
You should purchase a new phone and try to avoid letting your pet elephant sit on it.
Regards,
Reddwolf25
Apr 12, 2009 | LG enV VX9900 Cellular Phone
A elephant sat on my phone and it wont stop vibrating please help
Most mobile phones are not meant to withstand an elephant sitting on them. In fact, over time, just sitting on them in your back pocket can cause damage. The only solution is if you have insurance claim it. If not, then check Ebay for a good used or new phone, go to the store, renew your contract, or I guess don't have a phone.
Sorry for the unfortunate accident!
Vtech Counting Fun Elephant Logo
Top Vtech Toys Experts
relojmesa
cloudranger
Level 1 Expert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
