Question about Citrix GoToMeeting
Problem with goto meeting
Hi
I cannot connect to GOTO meeting, I get the message
"A connection could not be established, please verify you are connected to the internet".
I checked with my help desk and there is no firewall. I was able to connect a coupld of weeks back though. thanks for your help.
  • 1 more comment
  • chiedu7 Mar 05, 2009
    i could connect a while a go, now even after reformatting & reinstalling XP I still cann't connect
    Chiedu7@yahoo.com
  • Anonymous Apr 01, 2009
    same thing - computer related- another computer on the same network works fine so its not a router or provider issue. The only thing I changed is a hard drive- how could that do it? I wonder if it has something to do with IRQ's or something or is that old school?
  • Anonymous Apr 02, 2009
    We use citrix GoToMeeting to host webinars, online conferences. In the last couple weeks, would-be attendees at two large clients report being unable to connect.
Change the date on the windows machine to today's date - bottom right hand corner right click on time or date/adjust time/date to today and that may do it.
Posted on Apr 01, 2009
Local area connection cable unplugged error message
goto start run, type cmd... in the black screen type ipconfig.... this will tell you if you have any connections. if you get numbers like 192.168.1.1.... you are connected. if not . goto network connections make sure all connections are enabled.. if they are replace the cat5 cables and redo... if still no luck check all incoming connections to home
Dec 25, 2010 | E-Machines eMachines Desktop PC
Loader Error - GoTo Meeting GoToMeeting failed to start, or exited with an error. Please try again
after clicking meet now it shows connecting but within a second it give error that this meeting id has expired.please check with the meeting organizer.
so what could i do plz help me
Jan 31, 2010 | Citrix GoToMeeting
Hi I am using goto meeting and outlook
I haven't used GotoMeeting with Firefox or Thunderbird but there are known issues if you are using an older java plugin. If you are using JRE 1.5, try upgrading that to JRE 1.6 and see if that helps.
All of Sun's downloads are here:
http://java.sun.com/javase/downloads/index.jsp
Sep 10, 2009 | Citrix GoToMeeting
MY EMAIL ACCOUNT RECEIVES EMAIL, BUT I CANNOT SEND EMAILS. WHEN I ATTEMPT TO SEND, I GET THIS ERROR MESSAGE: ----The server does not support a SSL connection. Account: 'Microsoft Mail Server', Server:...
It seems that there is some problem with your settings. Goto account settings-> select the email account -> advanced settings of Outgoing server tab. Removing the check mark present near something like "SSL connection". save it and try again. Also verify other ports and outgoing server address by checking with your email provider.
i hope this is helpful to you
Sep 08, 2009 | Computers & Internet
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
Linksys WMP45G will not connect to wireless modem
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Jun 09, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Compaq presario wireless button no longer working
There is a mechanical problem with the R3000 wireless button and volume-down button where they seem to push fine but are in fact failing to make electrical contact. I know of two work-arounds.
* Try pushing the button with a capped pen, gently at first, and then with increasing pressure. (Not so hard you break the plastic, please!) I suspect this gives the buttons just enough extra "oomph" that contact is established.
OR
* Push up on the battery compartment while pressing the buttons. If the battery is in, you can acheive this same effect by putting your laptop on a table and popping up the screen, then applying downwards pressure on that corner of the laptop body while pushing the button. I suspect this aligns things properly so that the button is able to depress just a hair further.
You may even find that these actions "loosen things up" enough to cause the buttons to work like new for a little while. I hope this works for anyone reading this!
Oct 03, 2008 | Compaq Presario R3000 Notebook
MTNL ADSL connection through G834 G Netgear Router
Goto Settings> Control Panel> Network Connection> Network Setup Wizard.
Create a New Network Connection using this method and retry after the system restarts.
Goto www.sahajayogamumbai.org to attain your Self Realization and find a Sahaja Yoga Center to goto.
For anywhere else, goto www.sahajayoga.org.in or www.sahajayoga.org.
Feb 29, 2008 | NetGear DG834G Router
Computers & Internet Logo
2,465 people viewed this question
Top Citrix Computers & Internet Experts
xxxxxx xxx
alibaba69
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
