Question about Philips Magnavox 27MS343S 27" TV
Overscan is off a bit
Have this 27" magnavox (27MS343S) which seems to have a problem with the overscan. it looks as if the TV is trying to show a 16:9 picture b/c it cuts off the sides. Unfortunately there's no 'format' setting in the OSD menu to change it to 4:3 or 16:9. I'm told it used to be normal, but at some point it changed to this excessively large picture. how can i adjust the picture size/format? I've tried entering service mode using some of these codes folks have published but this 2003 model TV doesn't seem to accept them. i'm not even sure this is fixable in service mode. Any thoughts?
    Scholar:
  • 47 Answers
Does's the set have a repair history? If it was previously serviced , the capacitor which is connected between the emitter and the collector of the horizontal output transistor transistor might have been changed with the wrong value, which would cause and overscan situation.The service menu for this set is even hard for technicians to use. It' my opinion if the service manual will not correct the horizontal width, the wrong capacitor was probably installed. Scrivitron (also these sets are known for the forementioned capacitor to short , flame or open.
Posted on Jul 09, 2007
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
Television vertical overscan
Hello!
Please check the "Troubleshooting" part of the manual to this TV.
https://manualsbrain.com/en/manuals/1874651/?page=24
Aug 31, 2017 | Insignia Televison & Video
I can not get "fullscreen" on tv via laptop--when i click the "fullscreen " icon in laptop toolbar it freezes tv rather than going full screen
You should search for how to get "overscan" on your laptop model. ... I have a mac mini plugged into an LCD tv and in order to get it fullscreen i had to enable overscan.
Oct 27, 2008 | LG 42LC7D-UB Television
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Overscan
do you mean the top of the picture is cutt off? if so then go into tv menu and set screen size to 16:9 not auto. if that doesnt work then try settings on ps3 hopefully that works
Jul 23, 2008 | Toshiba 55H70 55" Rear Projection...
Magnavox tve244239
There are vertical and horizontal adjustment in the tv, however it requires removing the rear cover.
If you are unsure of the adjustments rather let a qualified tech service the tv for you.
Apr 15, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox 37MF337B/37 overscan only sometimes problem
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Feb 06, 2008 | Philips Magnavox 42MF521D/37 Television
Overscan Problem
Switch to that input, and run the Auto Convergence for that input (Setup menu on the TV, Convergence). Convergence settings save for that particular input.
Dec 06, 2007 | Televison & Video
Zenith Z27X22D Service Menu Codes needed
significant vertical overscan. It is such that it's impossible to read crawls and such at the bottom of the screen. I think this problem is a tv problem. it is due to vertical section. please change electrolytic capacitor in vertical output section. it will be ok. it is common problem can be fixed at home & very simple.
Oct 03, 2007 | Zenith Z27X22D 27" TV
Philips Magnavox 27MS343S 27" TV Logo
379 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
