Question about Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White
Whirlpool gold gx5fhtxvy04
Not working. lights on and its is not cold
2 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: whirlpool gold side by side is thawing out and won't stay cold
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 27, 2009
My Whirlpool Gold Series Fridge is not cold in Fridge part, but is still working in freezer part. What might the remedy be?
Could be a few things. One could be a bad evaporator fan motor in the freezer section. The fan motor will only come on when the light switch is closed so make sure you hold down the light switch when you check it. Could be a defrost timer or defrost bimetal. You will know because you will have ice buildup on the back wall inside the freezer. Also could be icebuildup in the return air duct. They are located under the drawers in the refrigerator.
Oct 19, 2014 | Whirlpool Refrigerators
Whirlpool gold refrigerator electronics for icemaker and water are dead
Moisture damage or bad connection. Take apart and check wires and circuit board.
Jul 24, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
GX5FHTXVY04 slow leak in bottom of freezer.
Your Temperature Control for the Refridgerator is bad, once you fix it your problem will go away
Apr 12, 2013 | Whirlpool GX5FHTXVA Bottom Freezer French...
Whirlpool Gold GB2SHTXTS00, I bought it in 2007, but 3 days ago, the cooling suddenly is not working, but freezer and lights are fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Whirlpool Gold GB2SHDXPS fridge/freezer has stopped working. It is not cold and food is thawing. The light in the fridge and the freezer is still on but it is not cooling.
can you hear a humming sound coming from the back of the refrigerator, if so that means your compressor is running, if you are hearing a buzz or clicking sound your compressor is trying to start, you may need a compressor. Some whirlpools have a 5 year sealed system warranty that would cover the repair.
Aug 22, 2010 | Whirlpool Gold GB2SHDXPS Stainless Steel
Our Whirlpool Gold refrigerator is not getting cold and it is defrosted. The compressor is very hot. Our ice maker stopped working about six months ago and we replaced the cellinoid but it didn't fi
your Whirlpool has lost its gas charge , you will require a refrigeration mechanic to repair or if under warranty tell them to exchange it .
May 10, 2009 | Refrigerators
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side
if the fans are working, can you detect if the compressor is also working/running?
the compressor is located at the back side , lower portion. remove the back cover and observe the compressor if it is running.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White Logo
142 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
