Question about Texas Instruments TI-84 Plus Calculator
I get ERR: DATA TYPE
Every time I try to make a graphic. It shows when i press Y= and TRACE and GRAPH plz help fast :/
    New Friend:
Just had a student with this same problem. How we fixed hers was under memory (2nd +) select delete (or mem mgmt/del...) then select y-vars and "DEL" anything listed there.
Posted on Jul 18, 2013
    Sergeant:
  • Texas Instru... Expert
  • 265 Answers
Error Data Type mean that you entered a value or variable that is the wrong data type:
• For a function (including implied multiplication)
or an instruction, you entered an argument that
is an invalid data type, such as a complex
number where a real number is required. See
Appendix A and the appropriate chapter.
• In an editor, you entered a type that is not
allowed, such as a matrix entered as an element
in the stat list editor. See the appropriate
chapter.
• You attempted to store an incorrect data type,
such as a matrix, to a list.
Posted on Jan 14, 2013
t0pc4t
  • 132 Answers
SOURCE: "Err: Data Type" - Not Allowing Me to Graph
First, turn it on. Once the calculator is on, press the "2ND" key (I believe it is a blue key in the ti-84 plus silver edition). Now press the plus key (+). A little above that key, you should see the word "mem." When you see the screen titled MEMORY, move the cursor all the way down to the option that says "Reset." From here, you can choose to reset either the RAM memory, or the factory settings. The factory settings are the "Defaults" option. I hope this helps.
Posted on Aug 16, 2008
  • 3 Answers
SOURCE: ERR:DATA TYPE
Have you checked your "window" settings?
X min=-10
X max =10....etc.
Please post bck if this didn't affect it.
Hope this helps!
Rumblin_Racer
Posted on Mar 14, 2009
  • 33 Answers
SOURCE: Suddenly, the graph window reports ERR:UNDEFINED
Go to Window and make sure there are acceptable values for your graph, default is usually 10 and -10 with 1 scale.
Posted on Jul 17, 2009
  • 102366 Answers
SOURCE: i type in my y= and press graph then it goes
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Feb 21, 2010
  • 102366 Answers
SOURCE: when I graph, it shows "ERR: INVALID DIM 1:QUIT"
Posted on Oct 28, 2010
ERR: STAT PLOT
ERR: STAT PLOT meaning tha you are trying to display a graph when there is a StatPlot On that uses an undefined list
Feb 01, 2013 | Texas Instruments TI-82 Calculator
ERR:ARCHIVED
For future reference, some variable referenced in your equation has been archived. You can archive/unarchive variables and other objects in the memory menu available by pressing 2nd [MEM].
Jun 07, 2012 | Texas Instruments TI-83 Plus Calculator
I have filled my data but i cant get my median, upper quartile, lower quartile, top and low help??
Once you have filled a list, you can sort it.
As on the following screen press F6 to SET the graph type.
Use the F6 key to cycle through the options.
Press the keys to select the appropriate TAB at the
bottom of the screen. Select Histogram or BOX
Pressing the 1-Var tab at the bottom displays the statistics.
Press SHIFT F1 to trace the graph. Use right or left arrow
to display Xmin, Q1, Med, Q3, Xmax
Jun 29, 2011 | Casio FX9750GII Graphic Calculator
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
When trying to graph anything, ERR: INVALID DIM appears..
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
Cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
When graph get err dim how do you fix
ERR: DIM means your dimension (Xmin,Xmax that kind of stuff) can not show all of your data. You need to change your X,Y min and max so it fits. this usually happends only when you try to display plots of any sort. It is very annoying trying to get the right dimension....
Jan 12, 2009 | Texas Instruments TI-84 Plus Silver...
Graph and trace buttons don't work
This is probably because you have the stat plot on. You would need to go to y= and then go to the top where it says stat plot 1 and un highlight it if it is highligted. That should fix your problem.
Sep 16, 2008 | Texas Instruments TI-84 Plus Silver...
If either error occurs when trying to graph a function (not a STAT PLOT), the error can be corrected by turning off the STAT PLOTS. The following steps will turn the STAT PLOTS off, allowing the graph of the function to be displayed.• Press [2nd] [Y=] to access the STAT PLOTS menu.
• Select 4: PlotsOff.
• Press [ENTER].
• Try graphing a function like y = x^4-3x^3+6x-1
Jun 03, 2017 | Texas Instruments TI-84 Plus Calculator
Jul 25, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
276 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
