Whirlpool AWM 336 won't spin
  • Washing Mach... Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Posted on Jan 15, 2013
SOURCE: need to replace dispenser unit in whirlpool awm 336
OK, solved it now, you need to remove the front instrument panel first. This is held in place by four plastic lugs, two top and two bottom, which you can see when you remove the top of the machine. It's a bit fiddly since you don't want to break the lugs but a bit of patience gets it off clean. Next remove the two pipes that supply hot and cold water from the rear of the dispenser and also another pipe which fits onto the side. There are three small nuts to remove that secure the unit to the front of the machine and then by pushing it backwards and too the side it will slide out easily. Lastly there is a pipe to remove underneath the unit and then it is clear. Simply reverse the process to fit a new unit.
All the best
David
Posted on Feb 14, 2008
kakee
  • 1268 Answers
SOURCE: Whirlpool AWM 6145/3 gets stuck
That's a timer problem. Check on the user's manual on how to reset the timer settings. The timer can be replace if found defective but you need a pro technician to do it.
Posted on Aug 29, 2008
  • 207 Answers
SOURCE: Whirlpool AWM 293 600.
Replace the door switch.
Posted on Sep 04, 2011
SOURCE: Won't fully spin and alarms nd as a code
You may want to check your drain to be sure there's not a clog/partial clog when draining out the water. Also, you may want to check the filter and possibly clean it. A partially clogged filter may cause this problem. And, you might try...turning off the unit for 10 seconds and turn back on...select Spin Cycle...press Start/Pause to drain the water. Good luck and hope this helps.
Walt
Posted on Apr 26, 2012
kevin_getz
  • 1031 Answers
SOURCE: I have a whirlpool wfs1072Aw 7.5kg washer that has stopped spinning and won't start even the wash cycle
You probably have either a bad gearcase, timer, or lid switch. Defective motor is also possible.
Posted on May 08, 2012
I require an operation manual for a Whirlpool AWM302
The Whirlpool UK site has support for the AWM 302. The direct link to the manual is http://docs.whirlpool.eu/_doc/501910006566GB.pdf . If this isn't your model, start at http://www.whirlpool.co.uk/support/instructions-for-use/instructions-for-use.content.html and click on Search. Then search using the Commercial code box. (There are also washers with the commercial code AWM 302/3 and AWM 302/4.)
I hope this helps.
Jun 03, 2012 | Whirlpool Washing Machines
I have a model 336 Husqvarna chainsaw and it won't start. Put fuel into open plug hole replug, then turn it over it fires until the fuel runs out & won't restart & has full tank, obviously...
There has to be a kink in your fuel line ,or some blockage. Dump the fuel out ,then disconnect the gas line and try to blow air through the line.
Sep 04, 2011 | Garden
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Need to replace dispenser unit in whirlpool awm 336
All the best
David
Feb 13, 2008 | Washing Machines
Whirlpool awm 5145/4
FILTER MAY BE BLOCKED IRE CLOSE BYE
Nov 27, 2007 | Whirlpool AWM5145/2 Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
