Question about Maytag Dryers
Dryer flame shuts off after about 30 seconds
My Maytag dryer model MDG9700AWW has a flame for only about 30 seconds.Everything else keeps running (drum does not stop turning) but the clothes do not get dried up.
I do not know if it is the igniter or thermostat or something else.
Thank you !!
    Sniper:
  • 50 Answers
This sounds like a clogged vent more than a thermostat. go outside with the dryer running and see if hot air is blowing out the vent. if not check outside vent for birds nest etc, inside make sure the vent is straight any dips in vent could cause water to build up clogging the vent. try this first if it doesn't work write back
Posted on Jan 23, 2009
A Maytag dryer model MDG9700AWW that wont heat. I've checked both coils, replaced ignitor, high limit, both thermistors and the flame sensor. All appear good. there's no voltage at the ignitor when...
If there is no voltage at the ignitor, some safety device is prohibiting it. If the coils are good, it's being prevented by the control board or the first solenoid of the gas valve.
Jul 16, 2014 | Maytag Dryers
Maytag Dryer Model med5630TQ0, run it for 30 minutes works great run a second time for 30 minutes it automatically shuts-off and than I have to wait until it cools off to use heat option
Try cleaning out the vent in the wall and also check the vent hose to ensure its not kinked. If good air flow coming out of vent on back of dryer while running you could have a bad motor. Have to be disassembled to check it professionally.
Sep 25, 2017 | Dryers
My Maytag gas dryer model LDG9801AAL has irregular heating. The flame is not 100% bluish even after I cleaned the igniter glowbar. I already changed the dryer sensor but the flame keeps getting shut off...
if the flame is liting the ignotor is good,if the flame goea out after a minute or so then you have to clean out the dryer,unplug it,clean out the duct that the lint filter slides into,clean out the cabinet where the motor is and if the vent line is a long run i use a leaf blower to blow it out,pull it off the back of the dryer,stick the leaf blower into the vent and blow all the lint outside.one more thing if the flame lites and after 10 to 30 minutes thee flame doesn't lite anymore you have bad gas coils you can remove the cover down on the bottom right side of the front panel to check this,also you should clean this dryer at least once a year so you don't have a fire and your clothes will dry on time,pull the vent line off the back and see if it runs any better but you still have to clean the lint filter duct too,the block could be in there,bad air movement will cause this to happen.let me know how you make out.
Sep 25, 2011 | Maytag Dryers
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
My dryer ignites and after a few seconds the flame goes out
hold and assist coils
with model number i could get you the part numbers
Sep 29, 2009 | Maytag Dryers
Whirlpool model GGQ8858EQ1 gas dryer starts, gets flame and begins heating. then after a short while flame shuts off and i hear a chattering noise somewhere near the bottom of dryer. It lasts for about...
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at appliancepartspros.com. Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
May 05, 2009 | Whirlpool Dryers
Maytag mdet446ayw runs a few seconds and shuts off
maytag dryer mdet446ayw runs for around 30 seconds then shuts off
Apr 15, 2009 | Dryers
The flame does not stay on for more than 30 seconds i have replaced the coils
Hi. thanks for the question . The problem is with the air flow. Maytag dryers are known to have a blower failure . replace the blower . And clean all vents. Thanks the appliance doc
Sep 30, 2008 | Maytag MDG7600AW Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
381 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
