Question about LG 6322FR2046C Thermistor
Need Thermister replacement connector
I get an TE error on my LG washer, which the forums point towards the Thermister. Upon further investigation, it looks like one of the wires broke a the quick connector. I have searched all over for the name or where I can find this quick connector. The best that I can describe it is that it looks to me like a molex connectore with 2 wires. This piece plugs into the Thermister. Anyone know what this white connector is called? If I can't find this, can I remove the female connector from the Thermister side by cutting the heat shrink back and connect the wires directly without the connector? I'm pretty certain there is nothing wrong with the Thermister or control board, and this dangling wire is the issue. Help!
  • Mike Mikkelson Jan 14, 2013
    Here is a picture of the part needed, and where the wire broke off.
  • Mike Mikkelson Jan 15, 2013
    My wife was getting antsy tonight, so I soldered a wire into the plastic housing of the exiting plug, and the washer works again. I really would like to find the replacement to this part, since it's sort of MacGuyvuered together right now. Washer works again, but who knows for how long. Any help would be appreciated.
  • LG Master
  • 2,160 Answers
Cut the wires and wire nut them together. That will work.
Posted on Mar 25, 2017
  • 277 Answers
SOURCE: Loud noise when on spin cycle
hi the engineer probeply rejected agitator dogs problem sounds like he is right for the diagnosis on the bearings although it is very wired forthis problem on a new machine its probeply a defect bearing http://www.applianceaid.com/direct.html#agitating http://www.repairclinic.com/0047_11.asp good luck
Posted on Apr 30, 2006
SOURCE: te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Posted on Jan 10, 2008
dutchman05
  • 487 Answers
SOURCE: LG WM-2277HW Error "te" THERMISISTER OR ELEMENT FAULT - How do I fix it
I can give you THIS maybe that will help you . Service manual for your machine
Posted on Jun 19, 2008
SOURCE: Installing an overload switch (part #8201799)
I found the part I needed. Thanks anyway.
Posted on Apr 02, 2009
rlamkin
  • 44 Answers
SOURCE: black bar down middle of screen
these cables are machine installed on the panel itself, not user fixable. however, the cables are mounted to a circuit board at bottom of the screen. to reach they you need to remove nearly all the support structure and boards at the bottom of the panel. there are a number of sensitive parts under there and they have black 'licourus' on the chips to dissipate heat. good luck.
Posted on May 05, 2009
LG Front Load Washer
te is a error code for a bad thermister. it senses the temp of water in the tub. this needs to be replaced
May 01, 2014 | LG WM-2277HW Front Load Washer
I have te error
The thermistor temperature sensor in the machine is faulty and needs to be replaced.
TE = "Thermister Error"
The thermister sensor is connected to the main control board and relays the temperature of the water to it.
Sep 14, 2013 | LG WM2140CW Washer
My lg wm1832cw washer was in spinmode when it made a bam noise and lost power. I had to change the board ans when I did the upside down f and e came on. I changed the thermistor but am still getting the...
check the wire harness from main board to thermister. tE error code is either an open or shorted thermister. If you replaced the main board and thermister, the only other option you have is a bad harness. Reseat connectors on the main board and all along the harness to the thermister
Feb 10, 2013 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front load washer had code OE. Fixed the drain now it has the code EE. But the first E has the top missing from the E. Help
That would be a tE (thermister error). The thermister is located right next to or, on some models, is part of the heating element. It is nearly impossible to replace without taking the front off the washer. It is located right at the front of the outer wash tub. (just below the gray rubber door gasket)
Feb 01, 2011 | LG WM2455 Front Load Washer
LG wm2487hrm Washer not draining water. tE flashing. I drained water out of front and ran 2nd cycle same issue.
tE is a thermister error. It is a temperature sensor at the bottom front of the washer. tE can also be caused by a heater error. Some models have a seperate thermister, some incorporate it with the heater. It is very difficult to replace without taking the front off the machine.
Jan 25, 2011 | LG WM2487H Front Load Washer
Receiving a TE error code which leaves the washer unable to operate
TE is a thermister error. (temperture sensor) Located at the water heater element.
Supposedly can't be serviced by untrained individuals (thus the directions to call for service) but the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing.
thermistor is a small, round, black rubber grommet with the metal sensor pushed through the center.It easily pops back into place.
Apr 07, 2010 | LG WM-2277HW Front Load Washer
Error code tE
tE is a thermister error. (temperture sensor) Located at the water heater element.
Jul 06, 2009 | LG WM2688H Front Load Washer
Washer is showing "TE" error even after replacing the thermistor
Try pressing spin speed and soild level at the same time. Is the temperature about 10 degrees C over the the selected temperature? If no, then try replacing the main board.
Also make sure the thermister isn't loose. That could cause your problem.
If the main board doesn't fix it, then you have to replace the heater assembly.
Im actually looking the the service manual your unit as we speak.
May 27, 2009 | LG WM2277H Front Load Washer
LG 6322FR2046C Thermistor Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
